model 42-322 audio distortion
now that the restoration is complete with all caps replaced and deteriorated wiring redone, followed by a complete alignment, it receives stations on bcst and sw just fine. all tubes test good.
now the problem is the hum that was there before the restoration is even worse. on strong stations it doesnt just hum but it gurgles. the stronger the stations the worse it is.
would it help if I paralleled the filter caps with a higher value? also, would it help if I tied the negative side of the filter caps to the chassis instead of the end of the filament string? oh, I also found out you cannot tie the chassis to ac ground. it quickly blew the fuse I put in the ac line.
guess I need a refresher course in ac/dc radio theory and a good book on troubleshooting and modifications would sure help, along with a copy of the technical bulletins.
regards, Dick
Lotsa guys here going to have better advice than me, so I'll just say it's probably not anything to do with your power supply filters. Does it get worse when you tune in a strong station regardless of volume level or anytime the volume increases? Trying to get an idea if it's in the audio section or the rf/if/det string. Did it do it with the alignment signal?
kf4ns, Hi, don't parallel the electrolytics, you will put a strain on the rectifier. The electrolytics should not be grounded to the chassis they should be isolated from it bu sleeves or isolated mounting plates. I think you have a shorted cap somewhere since, depending on the size of the fuse, grounding the chassis should not cause a short. PL
Well guys, I found the trouble. It is one of my most embarrassing moments. For someone with my experience and qualifications in electronics I should be tarred and feathered.
I had added a single terminal of a terminal strip just to have a place for the ICL (inrush current limiter) and used a very strong glue called shoe goo to hold it to the chassis. I failed to notice that the rivit in the back was touching the chassis. I HAD TO HOT LEAD OF THE AC GROUNDED TO THE CHASSIS. What a dumb mistake!
With it now ungrounded the radio plays BEAUTIFUL and really pulls in the stations with remarkable clarity. NOW the project is done.
Thanks to all for the support. This was a very interesting project. My first excursion into the relics of the early 40's.
Dick KF4NS
Philco 91 Restore Code ??
Can someone tell me if my 42 tubes are connected triode or pentode in fixed or cathode bias? How could I tell by looking...dconant — 10:47 AM
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
There are currently 3987 online users. [Complete List]
» 2 Member(s) | 3985 Guest(s)
