Philco 15X Restoration, part 1
Recently found a Philco 15X here in NC. Cabinet resto will be in a different thread, probably next year as the weather here is getting too cold to work lacquer in my garage.
Chassis all there with some minor molestations. (both electrolytics, one resistor, some taped wiring)
All coils/transformers tested good with the exception of the detector coil (#15 on schematic). Primary was open, and attempts to find the break resulted in discovering that all of the wire was too brittle to be trusted. A victim of the HNO3 problem early Philco coils had.
http://i1194.photobucket.com/albums/aa37...012009.jpg
Above is the chassis after removal of the tuning condenser, filter choke, interstage transformer. I removed the volume and tone controls and the power transformer after the pic was shot. I am using blue tape to mask all sockets and holes in the chassis to protect the components and wiring under the chassis.
http://i1194.photobucket.com/albums/aa37...012011.jpg
Above is a different view. You can from here see that I have removed the cover to the filter bank. The caps inside the can literally fell out!!! If only all of them were so easy!
In the background of both pics you can see the two Mershons I intend to use in this resto. They will be re-stuffed with 50mFd electrolytic caps. Just kidding, they really will have 6.8 electrolytics installed.
I intend to use several methods to clean the chassis and remove rust. My plan is to have it, the tuning condenser, and the large tube shield in natural metal appearance. The only parts I will paint will be the power transformer, filter choke, and interstage transformer. Two parts I may have to paint will be the filter bank can and the round tube shield, as I am not sure that cleaning and rust removal will do them justice. FYI thanks to my friend and mentor Bob Timms for chassis resto advice.
The tuning condenser has been washed using HOT soapy water, then thoroughly dried, then washed down with WD-40.
http://i1194.photobucket.com/albums/aa37...012010.jpg
Above is a manilla folder (pholder??) that is being used to diagram everything I do to the radio. Using the folder gives you four durable pages on which you can do this. I strongly recommend diagramming when you are restoring a set.
After I have made some more progress, I will post part 2 with pics.
That chassis looks pretty good compared to the one in my Philco 96, at least there isn't any heavy rust scale. Are you going to paint the condenser can with that brushed nickel spray paint?
I'm going to experiment with different shades of silver until I find one that's right. If I knew a gun collector who could nickle plate or maybe chrome plate them I would consider that.
I will be watching this closely, i am getting ready to restore my 15X as well. One question, my large tube shield was missing when i got in. I will make one out of sheet metal but I need the measurements. Would you be willing to measure yours so i could reproduce one?
Philco Model 76 Highboy
Back in Feb I scored a nice model 95 Highboy, see earlier post.  Saved from a guy that likes chopping them up into Liquo...slford310 — 09:49 AM
Philco Model 71B
Adding a pic from the other side and the inside.  It will be a bit of work and a challenge but that's what makes it fun....slford310 — 09:32 AM
Philco 89B code 123 newbie
Hi Kurt Welcome to the Philco Phorum. Lots of phriendly pholks (see a pattern here?) who are happy to help.  Keep posti...MrFixr55 — 08:36 AM
Hello Kurt, Welcome aboard and you have a nice set to start on ! Yes, the bakelite blocks and I too find them fairly...radiorich — 07:12 AM
Getting started on my first Philco here, done some research and hopefully I now know enough to be dangerous.  :) Overal...Kurt P — 01:44 AM
Delco car radio Peko vibrator converstion issues
Richard, I reviewed the Panasonic specification sheets for this type capacitor and though dV/dt is discussed, there a...Chas — 11:48 AM
Philco Shipping Crate
I picked up a nice set of KLH 20 speakers ca 1980, for $40, and a Telefunken 5083W "Allegro" AM FM SW radio, a...MrFixr55 — 10:52 AM
Philco Model 71B
Absolutely looking at replacing the arch veneer and sides. Good luck stripping the front face ... hope the paint hasn't...GarySP — 10:31 AM
1953 Music Masters 620-9 Australian Radio Restore
That's a very interesting radio Buzz. Looking forward to more installments on this one!Eliot Ness — 10:31 AM
Philco Model 71B
OOPs, Dumb me. The title of the post is Model 71B. DUH!! Yes, the 71 uses an autodyne detector, but it is more like t...MrFixr55 — 10:21 AM
There are currently 2214 online users. [Complete List]
» 1 Member(s) | 2213 Guest(s)
