Philco 610 Condenser Block Question
I'm cleaning out two side by side bakelite blocks in my Philco 610. Both blocks have 4989DG inscribed on the side, so you'd think they'd be the same mfd. Looking at the schematic from Nostalgia Air, the part numbers 15 and 36 list these as 4989DG, but 15 is twin .09 and 36 is twin .1
Looking at the bakelite block list on Philoc Repair bench I see the Universal 4989DG @ .1 , but the 4989 @ .09 is listed with different letters, ie. 4989B, 4989C, or 4989G... which is correct, or does it matter?
Britt
Finally located the "second" 15, all four locations on the schematic specify .1 mfd, the parts list disagrees by a tad, Boy, get this close on an old Philco and I'd be happy as a pig in .... None of the locations look critical, use the .1 mfds. Still well within tolerance.
Rick,
I guess I'm suffering from "duh...look at the schematic" syndrom. You're absolutely correct after I looked at the Nostalgia Air schematic it shows both 15 and 36 to be .1mfd blocks, just like what is stamped on the side of the blocks. Next time I'll confirm the parts list against the schematic before wasting everyone's time on the Pfhorum....! I'm electronically challenged, so I make alot of beginner mistakes
Thanks for the response !!!
Britt
Never hurts to be careful. These old Philcos can be a challenge when things don't add up. Regards
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2354 online users. [Complete List]
» 2 Member(s) | 2352 Guest(s)
