Dial Cord Slippage ?? 42-PT95
I am hoping this is a simple fix. I have two 42-PT95's that are experiencing similar problems.
When I get near the bottom of the dial (say around 1400 KC) and I turn the tuning knob slowly the dial pointer (and tuning gang) gets stuck and will stay around 1400. If I turn the knob back a little, and then twist it fast it will unstick and move past 1400, sometimes to 1500 sometimes all the way to 1600.
I know that it is not just the pointer that is off, because I have a station at 1450 that I cannot tune if the dial/gang gets stuck. After I twist fast, it will move past 1450 and I will have to go down the dial to tune in the station.
Could this be dial cord slippage ? would some rosin (say from a music store) do the trick ?
Thanks again. This forum has been a very valuable resource !
Sure seems like slippage. Let's see, at 1450 tuning gang would be almost fully open. I would try spraying a little WD-40 in a cup and apply a tiny amount with a toothpick on the bushings or bearings of the tuning capacitor as well as any other ancillary pulley bushings. I would also check to see if the dial cord spring is giving some tension to the cord. Dial cords sometimes stretch, and sometimes there are 2 or 3 holes provided for the spring's anchor to increase tension for just this purpose. Yes, a bit of rosin rubbed into the string might help, but it would probably be temporary. Some just bite the bullet and restring. While doing so, the control shaft area where there the string is wound on would have to be cleaned up really well, maybe even roughed up a little with very fine sand paper to provide a little "tooth" for the string.
I assume the dial indicator is not hanging up the mechanism, but to be thorough, check it too.
Thanks CodeFox, I will attempt to do so.
What diameter dial cord should be used 0.030" or 0.040" or doesn't it matter ?
Doesn't matter much.
Philco 60 Squealing
Wondering if I did it backwards. If a coil was wound backwards, the oscillator would not work at all. Old school...Chas — 07:23 PM
Philco 38-7 Speaker
4-ohm speaker. Black, Green leads.tludka — 07:00 PM
Philco 42-390, code 121 speaker
#87 on the schematic.  This radio had a 8" Zenith  speaker attached to it when I got it. I do don't know the hist...Stevelog — 06:39 PM
Philco 60 Squealing
I'm pretty sure I now have the litz wire soldered. This did not make any difference. Back in April I rewound the seconda...dconant — 06:25 PM
Philco 38-7 Speaker
Just to make sure, you chose either 4 ohm into 5K or into 10K? (blk-org or blk-grn)morzh — 06:23 PM
Philco 38-7 Speaker
I have let this one sit because of other duties. Now I am back, and I have a couple of questions. I hooked up a Hammond ...tludka — 05:34 PM
>>A closer examination of the very small print schematic indicates that the speaker is a PM type. This shows a ...morzh — 05:18 PM
Philco 60 Squealing
Litz is typically tinned by simply rubbing it with the soldering iron tip while immersed in solder (and a bit of rosin f...morzh — 05:14 PM
Philco 6K7
The suppressor grid (if by G3 you mean the S) is usually at the Cathode potential, which in this caes is GND. I am not ...morzh — 05:10 PM
Philco 16B Parts
Thanks for the reply. Unfortunately the radio was removed before bidding was over so I didn't get a chance to bid.dconant — 04:10 PM
There are currently 4729 online users. [Complete List]
» 2 Member(s) | 4727 Guest(s)
