Grunow 588
Ok, I know it was a mistake, but I strayed from Philco. I picked up a Grunow 588. I got it for only $38.00, but now I'm stuck.
I replaced (very carefully) all the electrolytics and paper caps as well as any resistors that were out of range. The tubes were tested and replaced as necessary. All I get is a low hum. I get nothing if I touch the center lug on the vol control.
Any ideas?
Eric
Eric
The Villages, FL
Schematic here I think this is your set :
http://www.nostalgiaair.org/PagesByModel...008378.pdf
You may be able to scare up a clearer image and more information elswhere
I'd check the plate voltages (measure to B- rail) and make sure the output transformer and field winding is good and and wiring is OK. Well, then it's just a mater of working backwards from the speaker to find the point of failure. Frankly I wouldn't trust any of the carbon resistors in a set this old, no matter how they measured cold.
Thanks, I'll check these and get back to you.
Eric
The Villages, FL
Time to show my ignorance/inexperience. What is the B- bar? Isn't it just ground on the chassis? This is an A/C radio.
From what I've found so far the plate voltages are all there but I can't seem to get any filament voltage readings but the tubes are hot. Any thoughts?
Eric
Eric
The Villages, FL
It would be the center tap of the HV winding of the power transformer.
Hey Guys,
I got ot working! What a great feeling. I wish I could tell you exactly what I did but I can't. All I did was take out the tubes and retested each one. Turned it on and it works great. Just aligned it and it pulls in stations really well. BC and SW.
Thanks for everyone's help,
Eric
Eric
The Villages, FL
Aye. 76
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2118 online users. [Complete List]
» 1 Member(s) | 2117 Guest(s)
