Zenith K725 Gone Belly Up
I have a dead Zenith K725(similar to H725). There's not even static on it and I'm assuming without testing as yet the SE-1 selenium rectifier is bad. Oddly enough, last night I had it playing, turned it off after about an hour and tried today and totally dead as if not even plugged in. The tubes do light but that's it. Any suggestions would be appreciated.
http://web.mit.edu/gr20603/www/website%2...01_192.pdf
Could be a number of things, although it is true that solid-state components either work or do not.
Test your tubes. A bad tube can still light up.
Test your coils/transformers, an open one can make your set exhibit the same symptoms.
I have to plead guilty on this one. I accidentally flipped the switch on the loop antenna that apparently switches it from radio to phono. Once I flipped it back it kicked in. I wish all fixes were that simple.
THAT is the BEST kind of fix!!!
Icon_thumbupIcon_wink
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
