tube numbering
Hi Guy's,
Does anyone know the numbering sequence on a number 42 tube(6 pin).
I need to know which is number one pin.
murf
The two thick pins are 1 and 6. Pin one should be the thick one on the right viewed from the tube bottom IIRC.
One cannot forbid people to be idiots....all one can do is try not to be one. -Morzh
That's what I thought.
Wanted to make sure.
Thanks
No, no, no, no!
Pins 1 and 6 are indeed the larger of the two pins, but as viewed from the bottom Pin 1 is the large pin on the left. You then count clockwise from there - 2, 3, 4, etc.
Take a look at this link - it shows the correct numbering for the 42:
http://www.nj7p.info/Common/Tube/SQL/Tub...hp?Type=42
Looking at the tube from the bottom? Under the chassis looking at the bottom of the socket I thought it was on the right... Yikes... Hope I didn't hose you up!
Yup, from bottom because that's how the repairmen or builder sees it. The fatt pins on old tubes are always the filament.
An RCA Receiving Tube Manual is a good thing to have. They diagram each tube and have the pin numbers (bottom view).
For the older sets with tubes like the 42 you should have an older manual, as the newer ones list the older tubes in the back of the manual but do not include the pin diagrams.
FYI a tube substitution manual is another good resource to have on your bench.
The anti-intuitive nomenclature was no doubt invented by a very clever Kangeroo.
You can get old time manuals and keep you reading for the next century here:
http://www.tubebooks.org/technical_books_online.htm
Need Help to ID this radio 11 tube Philco
Philco 16 is not intimidating at all. Despite being an 11-tuber. 37-116 is indeed intimidating. 16 has good space unde...morzh — 04:11 PM
48-482 rear panel help
Thanks for the responses Gary and Bob. I'm a little surprised that there's no back panel - although I know older Philco'...keithchip — 04:09 PM
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
There are currently 2122 online users. [Complete List]
» 1 Member(s) | 2121 Guest(s)
