Threads: 50
City: York PA
When I bought this radio from a radio person, he explained away the following note as "probably caps": 80 tube overheats, do not energize until problem is found. So I took out the 80, and did some voltage checks. The voltages to the 80 were right on. Filaments to the other tubes OK. Field coil OK, choke OK. So I stick the 80 in and at around 80 volts, there are little sparks on the 80 tube socket (from underneath) and I quickly shut down. The 80ST shows shorts and no filaments.. I hadn't checked it before this. Now, before I start the lengthy (but enjoyable  ) recap, do my initial transformer checks rule out a transformer problem? Anything else to check first? Suspects?
What schematic do I want to be looking at? This chassis has a band switch; the on/off is with the volume. The electrolytics don't match up with 18 schematic. For example, I don't have part #s 59 & 60 (8uF & 10uF and 8uF), I have a 20/20/20 can.
(This post was last modified: 12-30-2012, 06:16 PM by DKinYORKpa.)
Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
If it has two bands (AM and the "police" band), on-off with the volume control, then it is the early 18 - not the later Code 124 (AM only) version.
Threads: 50
City: York PA
Quote:then it is the early 18
Is this something that I have to get from The Philco Repair Bench?
Ah, I see what you mean - the early 18 isn't at Nostalgia Air.
Well, if you want good, clear, readable schematics with all production change notes, etc., then - yes.
Threads: 1
City: Utah
Well worth the 7.00 from Chuck.
Threads: 50
City: York PA
Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Electrolytics this time.
Quote:Well worth the 7.00 from Chuck.
Check went in the mail today.
DKinYORKpa Wrote:Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Okay, just trying to help...good luck...you may need it.
Threads: 50
City: York PA
Quote:Okay, just trying to help...good luck...you may need it.
I love your help! Now, why may I need good luck??????
Threads: 112
City: Medford OR (OR what?)
If you saw sparks in or under that socket and it is a wafer style, then you better keep an eye on it after you are done. Any arc will burn a trace between the layers of the wafer resulting in a HV short that just gets worse.
And that was the point I was trying to make, DK! Phlogiston is 100% correct.
Now, let's all go put some extra Chivas Regal in our New Year's drink for this evening and have a nice night.
Threads: 112
I still have a transformer to wind. Will Chivas Regal help - you know it will!
My Philco 37-116 Restore
Are you measuring relative to the centertap or the GND?morzh — 11:57 PM |
Still not clear on the wiring interface between the 6A7 and oscillator. After refering to the available schematics and s...Tubester — 07:18 PM |
Refinishing Ideas
My 37-116 code 121 is the best sounding radio i have...a daily driver. Since we are talking about "changes". ...poulsbobill — 07:18 PM |
Hello, I finally got brave enough to take the cans off the Expander Unit. Got the grid cap wires replaced and back toget...dconant — 06:50 PM |
I got into the first AM IF can today, and found its mica was cracked. Amazing that it was still working. This one makes ...EdHolland — 06:10 PM |
Philco model #20
AHH HA , I got it and can’t thank you fellows enough , when I changed the capacitors I took the advice and did not unsol...onlyrick — 02:24 PM |
Hello Ed,
yes, I like letting projects run for few days to make sure they don't start acting up .
Sincerely Richardradiorich — 01:03 PM |
I am almost finished with this restoration. All which remains is the power transformer. I cleaned it up some time ago, b...jrblasde — 12:41 PM |
Philco model #20
I seem to recall in some TRF sets there being a Local/Distance toggle switch that removes the B+ from the first 24 rf tu...RodB — 09:46 AM |
Refinishing Ideas
Hi Doppelganger,
After rereading your thread, did you mount the Zenith speakers in the two bottom left and right pos...MrFixr55 — 09:39 AM |
