Threads: 50
City: York PA
When I bought this radio from a radio person, he explained away the following note as "probably caps": 80 tube overheats, do not energize until problem is found. So I took out the 80, and did some voltage checks. The voltages to the 80 were right on. Filaments to the other tubes OK. Field coil OK, choke OK. So I stick the 80 in and at around 80 volts, there are little sparks on the 80 tube socket (from underneath) and I quickly shut down. The 80ST shows shorts and no filaments.. I hadn't checked it before this. Now, before I start the lengthy (but enjoyable ) recap, do my initial transformer checks rule out a transformer problem? Anything else to check first? Suspects?
What schematic do I want to be looking at? This chassis has a band switch; the on/off is with the volume. The electrolytics don't match up with 18 schematic. For example, I don't have part #s 59 & 60 (8uF & 10uF and 8uF), I have a 20/20/20 can.
(This post was last modified: 12-30-2012, 05:16 PM by DKinYORKpa.)
Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
If it has two bands (AM and the "police" band), on-off with the volume control, then it is the early 18 - not the later Code 124 (AM only) version.
Threads: 50
City: York PA
Quote:then it is the early 18
Is this something that I have to get from The Philco Repair Bench?
Ah, I see what you mean - the early 18 isn't at Nostalgia Air.
Well, if you want good, clear, readable schematics with all production change notes, etc., then - yes.
Threads: 1
City: Utah
Well worth the 7.00 from Chuck.
Threads: 50
City: York PA
Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Electrolytics this time.
Quote:Well worth the 7.00 from Chuck.
Check went in the mail today.
DKinYORKpa Wrote:Quote:Bad 80 tube socket? This has been known to happen in Philcos of this vintage.
Okay, just trying to help...good luck...you may need it.
Threads: 50
City: York PA
Quote:Okay, just trying to help...good luck...you may need it.
I love your help! Now, why may I need good luck??????
Threads: 112
City: Medford OR (OR what?)
If you saw sparks in or under that socket and it is a wafer style, then you better keep an eye on it after you are done. Any arc will burn a trace between the layers of the wafer resulting in a HV short that just gets worse.
And that was the point I was trying to make, DK! Phlogiston is 100% correct.
Now, let's all go put some extra Chivas Regal in our New Year's drink for this evening and have a nice night.
Threads: 112
I still have a transformer to wind. Will Chivas Regal help - you know it will!
Correct model 84 Ac plug an cord type
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM |
Hi Bruce,
I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM |
Restoring Philco 38-14
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder.
I put a scope on the o...morzh — 08:15 PM |
Hello Bruce,
I mostly use brown far as my cloth powercords go !
Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM |
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM |
Rod
Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios...morzh — 10:11 AM |
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM |
hello morzh ,
That sounds like a plan !
Sincerely Richardradiorich — 07:45 AM |
Richard,
It helped some, but I still had the whining when engaging the rear power strip (I did not realize it was fro...morzh — 07:07 AM |
Hello morzh,
Yes , that dreaded hum in my room where i do alighment I have my cable modem and router plus desktop plus ...radiorich — 11:25 PM |
