01-04-2013, 12:24 AM
Philco 15DX restoration
01-06-2013, 05:41 PM
I've moved onto cleaning up the chassis. I also gave the tube shield a fresh coat of metallic paint.
[Image: http://farm9.staticflickr.com/8362/83555...81d9_c.jpg] The old rubber mounts are rock hard so I'll need to find some new ones. [Image: http://farm9.staticflickr.com/8325/83555...e923_c.jpg]
01-06-2013, 08:36 PM
I think that those mounts were some sort of rubber grommet propitiatory to Philco, sort of like those triangular chassis shock mounts on some sets, I don't know where anyone is making repros or no. The closest thing I can think of to those are maybe shock mounts for a small refrigeration compressor, or you can try some thick washers with the same size center hole. The only other answer would be to make a mold and cast some out of a D.I.Y rubber compound, if you can still get it.
Regards Arran
01-06-2013, 09:47 PM
If you go to someplace like Graingers and look for rubber vibration isolators there is a pretty wide selection and perhaps something might be close enough or be adaptable to what you need: http://www.grainger.com/Grainger/cylindr...sst=subset . Renovated Radio also seems to have some rubber repro items though not these exactly but it might be worth an ask.. http://www.renovatedradios.com/parts.html
Bob
01-07-2013, 12:36 AM
Here is the rubber grommet selection form Grainger which may be worth looking through:
http://www.grainger.com/Grainger/rubber-...-c1x?xi=xi Regards Arran
01-07-2013, 11:01 AM
Another option is to start with some laboratory rubber stoppers and adapt them http://www.amazon.com/Best-Sellers-Indus.../393458011
bob
01-08-2013, 03:04 PM
Thanks for the suggestions. I think I found some items from renovated radios that will work. I needed to order some other stuff from them anyways
01-11-2013, 12:18 AM
My order from RR arrived today. I think these will work out fine.
[Image: http://farm9.staticflickr.com/8093/83696...5a08_z.jpg]
01-11-2013, 12:35 AM
I've also been examining my speakers more closely and discovered that the Wheelers are not made very well and the cones don't have much spring left in them. So I pulled out the original Philcos for another look. After some careful scraping and compressed air blowing, I actually got the voice coils moving fairly well and decided to patch them up.
[Image: http://farm9.staticflickr.com/8356/83686...8f09_c.jpg] Yuck! [Image: http://farm9.staticflickr.com/8185/83686...6a3c_c.jpg] [Image: http://farm9.staticflickr.com/8190/83686...752b_c.jpg] Making good progress [Image: http://farm9.staticflickr.com/8465/83697...2518_c.jpg] I used GC Service Cement and coffee filters to patch up the cones. [Image: http://farm9.staticflickr.com/8505/83686...3c52_c.jpg] I figure if these actually work, I'll recone them properly. I think the radio will be happier with the original speakers back in it [Image: http://farm9.staticflickr.com/8471/83686...81c6_c.jpg]
01-11-2013, 02:13 AM
Bob, nice that your putting back in the originals. A lot of work to clean them up but I think you will be happy. Looks like they are coming along well. Nice job.
Jerry A friend in need is a pest! Bill Slee ca 1970.
01-12-2013, 04:03 PM
Looks good so far. Hope the iron windings are OK. Best take it slow on the cones.
01-17-2013, 06:14 PM
I figure I might as well polish up the aluminum IF cans before I remount the tuning cap. I hope to fire it back up tomorrow.
[Image: http://farm9.staticflickr.com/8080/83909...a6bd_c.jpg]
01-17-2013, 07:35 PM
Bob, I'm not certain what you used on those cans, but the came out absolutely lovely. Nice job. Are you going to keep your method secret?
01-17-2013, 07:54 PM
WOW!
-- Ron Ramirez Ferdinand IN
01-17-2013, 08:59 PM
Thanks! Your answer is right in the photo - Simichrome and a cotton cloth. I cut the cloth into a long strip about 3 inches wide, dabbed on a little Simchrome, wrapped it around the can, grabbed one end in either hand and buffed the cans like I was shining shoes. I used the same stuff on the copper caps.
« Next Oldest | Next Newest »
Users browsing this thread: 7 Guest(s) |
