Modified Philco 48-1201 talking book record player
I'm sure everyone is familiar with the common Philco 48-1201 "Bing Crosby" AM radio/78 rpm record player. Several years ago, I found a beat up version that was modified to play talking book records for the blind. On the back of the unit is a metal plate that reads, "Talking Book Reproducer, model AC-47, American Foundation for the Blind". I don't know if this unit was actually modified by Philco, of if these units were purchased from Philco and then modified by AFB.
There are several differences between the standard version and the talking book version. The TB version plays 33 rpm records, as well as 78 rpm records and the speed selector lever is located in the lower left hand corner of the machine. Library of Congress talking books were recorded at 33 1/3 rpm between '34 and the late '50's. Later records were recorded at 16 RPM and 8 RPM. The TB version has a device for placing the tonearm on any place on the record. This is accomplished by a wheel that, when rotated, lifts the tonearm, moves it over a little, and then drops it back on the record. This wheel is accessed through a hole that was added to the right hand side of the machine. There is also a pause lever on the rear of the machine that can be used to raise the tonearm. There is also a headphone jack on the rear of the machine and the tonearm is fitted with with what I believe to be a high output magnetic cartridge with a counterweight at the rear of the tonearm.
Like I said earlier, this model is in fairly rough shape and someone had performed some hack repairs to the chassis. It is currently taken apart in a box; but, I hope to someday restore it.
I also have an unrestored; but, decent looking, standard version and a parts (regular model) unit.
I'm legally blind myself and am a user of talking books (now on cassette tape and digital cartridges) and I have a collection of older "talking book" record players; so, I was happy to find this Philco/AFB model. So far, I've only found one other person who remembers this model. This person is also visually impaired and remembers this Philco model from his youth. He said that they were rare and couldn't believe that I found one.
Here are some pictures of it taken apart.
[Image: http://i538.photobucket.com/albums/ff341...co0001.jpg]
[Image: http://i538.photobucket.com/albums/ff341...co0002.jpg]
Pause control and tone arm placement mechanism:
[Image: http://i538.photobucket.com/albums/ff341...co0003.jpg]
Speed selector lever:
[Image: http://i538.photobucket.com/albums/ff341...co0004.jpg]
Hmmm. Never heard of such a thing as a Bing Crosby Special modified for Talking Book use.
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
Rogers Majestic R-646
Vlad; It's possible that the tar/bitumen using to pot the box may have lead to the failure of the transformer, either...Arran — 10:28 PM
Hi OSanders. another thing about the loop antenna is that it is directional. Try turning the radio in different direct...MrFixr55 — 09:19 PM
The 630v caps will do just fine. Physical size increases with capacity values and voltage. You don't have to replace 200...RodB — 09:09 PM
Help with Supreme 599
Good catch. The 589 is a better schematic but i dont understand how the voltage goes thru the meter to adj the line volt...daveone23 — 08:17 PM
Arron, Yes, I can see the differences in the interior design, but if you compare the schematics, they look very similar...Vlad95 — 06:57 PM
I am not sure how the loop antenna supposed to work but think I have figured it out. I had one lead on terminal 1 and go...osanders0311 — 06:56 PM
Thx Vlad.klondike98 — 06:54 PM
Hi Arran. I continue to disassemble and I see that the interstage transformer is completely beyond repair. It is placed...Vlad95 — 06:50 PM
