Philco 38-12
Greetings all,
I just purchased a pile of radios from a local gent. One of the gems is a Philco 38-12. Naturally that was the first one I wanted to see if it had potential or not. It does.
One question though, the volume pot is a bit noisy. It it possible to take apart the volume control casing and clean the insides? I seem to recall some sets you actually can, the others are expendable.
Any advice would be appreciated.
73 de,
Gary/N9VU
Yes Gary, it certainly is worth a try. Good luck, and congrats on your acquisitions!
Ron Ramirez Wrote:Yes Gary, it certainly is worth a try. Good luck, and congrats on your acquisitions!
Any idea where to look for info on this?
73 de,
Gary/N9VU
The case of the volume control is held on to the front of the control by a few, or several (depending on the manufacturer), tiny tabs. Turn the control down until you click the switch OFF. Then carefully pry those tabs up and pull the case (back part of the control including switch) partially off the control body. DO NOT turn the shaft while it is apart, so that the switch remains properly aligned with the shaft! Spray away with your favorite contact cleaner, also shooting up inside the switch for good measure. Quickly put the case back over the control body and hold it together with your thumb and forefinger while you twist the control shaft with your other hand, turning the control on and turning it up and down rapidly several times to work the cleaner in really well. Now fold the tabs back over the body and reinstall in the radio. If the control is now quiet and volume goes up and down smoothly, you've fixed it. But if it is still scratchy and intermittent, it will require replacement.
That's what I was looking for. Thanks again, Ron.
73 de,
Gary/N9VU
Philco model 40-100
Marion; By "newer style" carbon resistors do you mean the molded type with coloured bands rather then the BE...Arran — 01:00 AM
hello jrblasde , your radio sounds great well done !! I bought like 20 years ago a Philco 610b that someone had painte...radiorich — 11:50 PM
Philco model 40-100
Arran, I just can't tell if the volume control has been replaced. The control has a brass shaft with one half flat for ...mhamby — 11:08 PM
Philco model 40-100
You may be able to make the part out of wood. The particular vendor has a habit of disassembling radios and selling the...MrFixr55 — 10:09 PM
Used to get to Bentonville when I worked for a Walmart vendor....nice and sleepy back then. PaulPaul Philco322 — 09:49 PM
Philco Model 249 made in England
Did Garrard produce stand-alone turntables? The reason I ask is, when I was a kid my grandfather gave me a KLH Model 20 ...jrblasde — 09:37 PM
Neat looking set, definitely Euro- style. I am guessing that this is solidstate due to the vent holes (or lack thereof,...MrFixr55 — 09:32 PM
Haha, thank you sir! I’ve been eyeballing a 47-1230 console for sale over north of Bentonville, Arkansas for a while. Pr...jrblasde — 09:18 PM
@ Joseph, get off the porch and run with the dogs. You fixed one, grab another. @ Morzh, I think that we are the same ...MrFixr55 — 08:59 PM
Wow! Now that is something! I’ve never seen a Philco like that, but it’s pretty mid-century.jrblasde — 06:40 PM
