Philco 38-12
Greetings all,
I just purchased a pile of radios from a local gent. One of the gems is a Philco 38-12. Naturally that was the first one I wanted to see if it had potential or not. It does.
One question though, the volume pot is a bit noisy. It it possible to take apart the volume control casing and clean the insides? I seem to recall some sets you actually can, the others are expendable.
Any advice would be appreciated.
73 de,
Gary/N9VU
Yes Gary, it certainly is worth a try. Good luck, and congrats on your acquisitions!
Ron Ramirez Wrote:Yes Gary, it certainly is worth a try. Good luck, and congrats on your acquisitions!
Any idea where to look for info on this?
73 de,
Gary/N9VU
The case of the volume control is held on to the front of the control by a few, or several (depending on the manufacturer), tiny tabs. Turn the control down until you click the switch OFF. Then carefully pry those tabs up and pull the case (back part of the control including switch) partially off the control body. DO NOT turn the shaft while it is apart, so that the switch remains properly aligned with the shaft! Spray away with your favorite contact cleaner, also shooting up inside the switch for good measure. Quickly put the case back over the control body and hold it together with your thumb and forefinger while you twist the control shaft with your other hand, turning the control on and turning it up and down rapidly several times to work the cleaner in really well. Now fold the tabs back over the body and reinstall in the radio. If the control is now quiet and volume goes up and down smoothly, you've fixed it. But if it is still scratchy and intermittent, it will require replacement.
That's what I was looking for. Thanks again, Ron.
73 de,
Gary/N9VU
Philco Model 80 Transformer resistance
Just forget this number, it is useless anyway. Simply proceed with your project.morzh — 10:08 PM
My $0.02 is that it is a misprint. I tried to look up the value for the similar 84 and 37-84, and ther is no resistance...MrFixr55 — 09:51 PM
Thanks for the quick reply! Hmm...well that's good, so what am I seeing that's 1042 ohms on the schematic for the pow...Mike L — 08:46 PM
The DC resistance of the primary is 8 to 9 Ohm.morzh — 07:54 PM
I have a feeling the primary winding on the power transformer is bad. My resistance reading on the primary side is 9 ohm...Mike L — 07:48 PM
Rusty Tuning Condenser
I would try Naval Jelly and use a soaked pipe cleaner to get it where it needs to go.RossH — 06:56 PM
38-10T chassis Restoration begins
Hello Dconant , they sold mica to use as a insulator between transistors and their heatsinks too. Rob I will remove th...radiorich — 02:52 PM
Thanks for the info guys. I always wondered why the use of mica. Now I know.dconant — 01:52 PM
Most common plastics have a dielectric constant in the 3-4 range whereas mica is around 6. This means that even if you w...Steve D — 01:46 PM
It is acceptable but not desirable. Plastic is not an approved cap dielectric, and even though a reasonably thick piece...morzh — 11:52 AM
There are currently 3764 online users. [Complete List]
» 1 Member(s) | 3763 Guest(s)
