Philco 84 Problem
I have a Philco 84 that I have re-capped and have either checked or replaced all of the bad resistors. Things were going reasonably well during alignment. I was picking up three separate stations, one on each end of the dial and one in the middle. Then for some unexplained reason things changed.
First, the only time the radio would receive is when the volume was turned completely up. There is no sound that comes out of the speaker unless this is done. This is a new problem that I can't seem to isolate. Furthermore I have no selectivity in the tuning, I get one strong station all across the dial and no others. Any Help would be appreciated.
I'm willing to bet your oscillator coil primary is open. I've restored three or four of these and they all had this symptom. It's not hard to rewind this part of the coil. Try to get the wire size close and the number of turns the same as the old coil. If it won't oscillate, reverse the connections. Remember too, that this radio needs a good antenna and ground to operate. It was Philco's cheapest offering at the time and while it will pick up all the local stations and sound pretty good, it is not a DX radio.
Steve Chambers
Warren, Ohio
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
Welcome to the Phorum, Phil! Lots of friendly help here to assist you along the way! Take care, - GaryGarySP — 10:55 AM
Hi Pdouglasti, Phirst off, welcome to the Philco Phorum, a Phamily Phriendly place phull of phun pholks and all things ...MrFixr55 — 07:37 AM
Hi Richard, It is starting to get nice on LI also.  However, this week is a total wipeout.  I am in a really good Ca...MrFixr55 — 06:48 AM
At long last, it is aligned! I’ve uploaded a couple of new videos to YouTube to demonstrate. YouTube picked up on Hall a...jrblasde — 10:08 PM
Hello Phil, Welcome aboard what is the model number of that radio ? Sincerely Richardradiorich — 10:06 PM
There are currently 1665 online users. [Complete List]
» 2 Member(s) | 1663 Guest(s)
