Admiral 7T10
Started work on Admiral 7T10. Recapped and all new resistors. Tubes all checked good. Only get one station across the dial. Narrowed down to oscillator- I think. Voltage readings on 12SA7 tube as follows:
Pin 1--0
Pin 2--13 vac
pin 3--83 vdc
pin 4--83vdc
pin 5--0--should be -7
pin 6--0
pin 7--26vac
pin 8-- -5.2--should be -.8 The only caps not replaced were C2 and C11- both are ceramic 50pf and 20pf.
How to check for bad oscillator? Could C2 and C11 be open/shorted.
http://www.nostalgiaair.org/PagesByModel...000212.pdf
Certainly looks like the oscillator is not running. I would check the oscillator coil for continuity before looking at those two caps. Not likely (but possible) that they are your problem.
Jerry
Agree with Jerry. You can test the osc coil in circuit all three pins should have have continuity to each other , a low resistance in the order of 10 ohms or less. If not that's your problem. Universal replacement are available from AES.
Got a 7T04 in the basement myself.
Thanks guys. I get a few ohms on one set and nothing between the other.
I looked on AES site and there are three replacements available. Which one? Should I replace C2 and C11 while I'm there? I can order them all together.
Joe
Your call Joe on the caps. Seriously doubt they are bad but the shipping costs as much as the parts, might as well throw them in the order. JMHO I will let someone who knows more than me to suggest the replacement coil. That would include most on the Phorum.
Jerry
Links?
Terry, I believe this will get you there.
Jerry
http://www.tubesandmore.com/products/rad...26%20Coils
Joe, looking at the schematic it appears the cheap 3 lead coil should do just fine.
Jerry
Thanks Jerry. Will order shortly and will let you know. Thanks to all.
Joe
Hi Joe,
You can try 3 wire osc coil and see if it works (probably will) but nice thing about the $9 one is that it has a slug in it so you can adj the frequency at the low end of the band. With other one you can only set the high end with the trimmer and the bottom falls wherever.
Actually years ago I had one of those Admiral set great player!
There are currently 1702 online users. [Complete List]
» 1 Member(s) | 1701 Guest(s)
