1936? model 84 resistor
#31
Hi Jim,
I'm pretty sure it's grounded internally but just to be sure you can check it with an ohm meter. Usually what happens is without a gnd connect to the set the volume control doesn't have much of an effect at all. Plays loud all the time. Did you try reversing the coil winding?
Haven't gotten to the coil yet. Still have to align the set. Am
going to get the "Ron Special" ball-point pen alignment tool
made this morning. The coil should be right on--counted turns
& made very sure to wind in the correct direction. Will see
what alignment will do for the old girl first.
Any idea other than humidity---what causes the Litz wire
to corrode on the coil windings? The set was obviously not
out in a barn--chassis is in very good shape for the age of
the unit. Thanks much for your help. Jim
#33
Well 1st off it's not Litz wire. It's just plain old 38G cotton covered stuff. There an interaction between that little clear strip and the copper that causes it to rot. Litz wire is made up from using several strands from very fine wire like 7-41 would be 7 strands of 41G wire.
ps Your very welcome enjoy doing it. It's kinda like fixing a radio with out doing the work! If it give you any trouble you know where to find me.
#34
It reminded me of Litz wire---came off in small pieces. I suppose Litz would have
come off the coil "dead"---this wire did have some spring to it yet. Thanks again.
Jim
48-482 rear panel help
Gary is correct, there was not a rear panel on the 48-482. I restored one of those and its a great sounding radio that ...klondike98 — 03:24 PM
A little light positivity in our feed... To nostalgic retro music... With English subtitles My new video on the contin...RadioSvit — 02:14 PM
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Need Help to ID this radio 11 tube Philco
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
There are currently 755 online users. [Complete List]
» 1 Member(s) | 754 Guest(s)
