Neat Philco AA5
Just completed a D-958 circa 1956.It has more bells and whistles than one might expect from that vintage AA5.It has a wood cabinet,mahogany finish,phono input,tone control,dual 6 inch speakers,neon power indicator,and 2 speed tuning.Outer tuning knob tunes the complete band in 1/2 revolution and inner tuning takes 3 revolutions end to end. Unusual for no SW bands. Also, output is 35C5 instead of 50C5. A 100 ohm resister is in filament circuit to drop about 15 volts.My guess is the AA6 was discontinued leaving an inventory of 35C5s which they were using up. Any other thoughts on this bit of trivia?
Correction--Model No is D-598.
It's more then likely that someone in the purchasing department got a deal on some 35C5 tubes, which they also would have used in a transformerless AM/FM set, they were also used in inexpensive radio-phonograph consoles in push pull sometimes. I've noticed this with some older Philcos, they will have a multiple code numbers of the same model where they will substitute one tube for another, like a 50L6 for a 50A5. The set you have may have shared it's cabinet and chassis with an AM/FM set, or at least some mechanical parts with an AM/FM set, there isn't really any reason to have vernier tuning on an AA5 at all.
Arran-I think you are right.Use of the 35C5 probably related to cost control measures-maybe discounts for large volume purchases to satisfy needs for AM/FM sets in addition to the AA5s. Cost of the additional resistor was probably minimal.Dual speed tuning was probably a sales gimmick-no real need.
You can sub 50C5 with no further correction due to today's higher wall current.
Hi Morzh, May be a good idea to remove the cone to prevent damage. You may have to do so anyway to remove the pole ...MrFixr55 — 08:44 PM
Philco 91 Restore Code ??
I think that Danaher, the company that owns Beckman-Coulter (the company that I worked for 41 years) owns Fluke. They a...MrFixr55 — 08:35 PM
Rod I wish... :lol: I am not sure I'd buy the Fluke, had it not fell in my lap for free. $500 to $800...it's a lot...morzh — 08:09 PM
Mike, ...you get a commission?RodB — 07:52 PM
New member
Hi. I specialize in refurbishing Predictas, but I'm in Chicago. If you can get it to me, I'd be happy to go over it. ...Bob Andersen — 06:43 PM
I have 3 G speaker, all with open Field coils. Today I pull one of the shelf and decided to try to remove the FC (spo...morzh — 06:07 PM
Thanks Mike. I will check them out.dconant — 05:52 PM
There is no such thing as bad Fluke. This said, they are expensive. A Fluke is easily 10x the price of comparable CCC...morzh — 05:45 PM
Hello Mike, Yes, I have 3 Fluke meters one being my first Fluke 77 and other being Fluke 87. My third is Fluke clamp -...radiorich — 05:04 PM
I knew that Fluke was the Cadillac so with that in mind what Fluke would you recommend I get?dconant — 03:53 PM
There are currently 2837 online users. [Complete List]
» 2 Member(s) | 2835 Guest(s)
