My 46-1209 has a 7n7 where the 7af7 should be. This radio has been in the family since new so should I keep the 7n7 or replace it with the correct tube
A 7N7 is a direct sub for the 7AF7. The only major difference is the 7N7 has a filament draw of 0.6 amps
vs 0.3 amps for the 7AF7. Is probably not a problem for your power transformer as tubes V4/V5 have a
seperate filament winding.
Checking the NJ7P Tube Database at http://www.nj7p.org/Tube.php , the 7n7 is a substitute for the 7af7 so if its working OK I'd leave it.
With regard to the speaker, unless the cone is so brittle that it crumbles as soon as you touch it I would try to repair...Arran — 04:07 AM
That silver can capacitor is an aluminum electrolytic. You should replace it with an aluminum electrolytic with the valu...RodB — 11:46 PM
