38-4 restoration need advice/ help
Threads: 13
City: Columbia, MD
Hi everyone, I am a new member with two 38-4 consoles. One is working fine with a recent recap (not by myself), and the other I have just recapped myself, and now have many questions so here goes... After replacing the paper tubulars and the elctrolytics, I reused the Mica caps, i tested socket voltages per bulletin #281, and noticed the DC readings were high. The power transformer is taller than my working set, and according to the part number stamped on it I have a 115v 25/40 hertz xfmr. Should I stop here and locate a 60hertz transformer? I do get recption on both bands, the volume level is low compared to the working set as well.
Threads: 270
25cy Transformer is ok. Sounds like you have other issues. Weak tubes or a bad resistor can give you those symptoms. Check voltages around the tubes to see where the problem is.
ps Where in MD?? Grew up in Sandy Spring.
(This post was last modified: 02-12-2013, 10:48 PM by Radioroslyn.)
Threads: 13
City: Columbia, MD
Tubes test OK on a heathkit TC2 ( not sure if thats a decent tester or not??) and play OK, in the working set. I have a order of resistors on the way from just radios, and I have to admit I only ohmed out about half of them when I did the caps. What tolerance should the resistors be within?
Also have a signal generator coming in the near future.
Terry, im down rt.108 in clarksville.
Threads: 18
Most older carbon resistors will have drifted way up in value or will behave strangely when under power. Nominal tolerence was 20% for most application. New ones with 5% or better toleranece are available for pennies apiece so it just makes sense to replace 'em all when doing a recap job. No foolproof to measure old resistors or capacitors.
Threads: 54
See if the voltage chart mentions anything about Ohms per volt with their readings. The resistors are worth checking even without taking voltage readings into account, especially on any resistor with a body end dot code.
Threads: 13
City: Columbia, MD
thanks, theres definatley some resistor problems, One which i tested last week is now open.... so ill dig in once they arrive. Anybody have preferrences on solder? I have some rosin core lead free, 96%tin, 4%silver. Is that OK?
(This post was last modified: 02-15-2013, 07:10 PM by conroyp.)
Threads: 574
Lead-tin eutectic solder's the best. Rosin core is good. I don't like leadless solder.
Threads: 13
City: Columbia, MD
The resistors have arrived, ill dig back into it this week.
I also got the rubber isolators for the tuning cap. Anybody know how to get the two in the front into place? Can they be installed without taking the tuning cap off the chassis?
Threads: 13
City: Columbia, MD
Been busy lately, All new resistors and caps. I aligned it, tuning and reception is good on both bands, but I need some help, the volume is low, and it seems like there is too much bass.
I also have some high voltages. These problems were present before, I figured the off spec. components were to blame.
the DC tube socket voltages are around 20-30 volts high, at 115vac input.
heater voltages are ok. Any recommendations?
[Image: http://i818.photobucket.com/albums/zz105...ae2f7f.jpg]
[Image: http://i818.photobucket.com/albums/zz105...90451c.jpg]
(This post was last modified: 03-21-2013, 04:18 PM by conroyp.)
Threads: 574
The DC tube voltages will be higher if you use today's Mains (120V vs 110V). You probably also use today's DMM and not the old type Voltmeter that would lower the voltage due to lower input impedance.
As for the volume low - Bass high,
1) Have you changed ALL capacitors and ALL resistors?
2) if not, start probing around the Switch #40 for all connected caps' and resistors' values.
3) If you haven't change #58/59 caps (likely to be micas not films) check them.
Threads: 13
City: Columbia, MD
Morzh, thanks,
I replaced all the resistors and all but the mica caps,
I used a variac to set input test voltage to the same voltage the schematic quoted for their readings (115v), line voltage just makes it worse.
Ill check over #40 with a meter, it does seem to work though.
#58-59 are new, Ill check them again.
Anything else???
Threads: 574
All parts 29-33 (caps-resistors). Especially 29.
Also....remote, but what if the output transformer is coming down with something?
In some cases the old paper caps can be replaced with ceramic caps, with values such as .001 uf, .005 uf, .01 uf, and ma...Arran — 06:50 PM |
Vlad;
I would tend to agree, I only suggested the loop antenna connections since he was already looking at the end of...Arran — 06:18 PM |
Rod thank you for helping to understand the paper caps and offering the bumblebee caps. I have already ordered film caps...osanders0311 — 03:55 PM |
Bob, this is the wrong sequence to look for problems and setup circuits.
Always start checking the signal path from the...Vlad95 — 12:19 PM |
Philco J1720 stereo and record player with reverb
The above link takes you to the Delaware Valley Historic Radio club. They are not too far from you and may have sugg...klondike98 — 11:49 AM |
Tucker Movie Prop car
Richard: Did you ever check with your friend? About once a year I try to verify if Mr Rhoades really worked on the r...WrenchMonkey — 09:22 AM |
>>when turning the knobs
This is very broad.
There are knobs for tuning and knobs for volume, and possibly f...morzh — 07:36 AM |
Thx Arran, I will check the antenna connections. Right now the loop is alligator clip connected to the chassis since you...klondike98 — 03:58 AM |
Bob;
I was just thinking that maybe the 1R5 tube doesn't like being operated at 1.2 volts on the filament, though you...Arran — 12:56 AM |
So I just purchased a Philco J1720 stereo and record player. That has some static when turning the knobs. Wanted to see ...PhilcoJ1720 — 12:26 AM |
