potentiometer question
Can anyone tell me the difference between a linear taper, logarithmic taper and audio taper pot?
Eric
Eric
The Villages, FL
Pots came in all sorts of tapers.
A linear pot will change the same amount of resistance per degree of rotation throughout it's range. These are mostly found in DC control circuits for metering, voltage regulation, eTc.
A log pot will change at log 10 or 20 per degree of rotation, depending on the engineering call-out.
An audio taper is usually some type of log pot, but the taper may be 'adjusted' for evenness in rotation to our human ears, so everything doesn't bunch up at the end (like a linear would on audio) and make adjustment difficult. A lot of audio pots used in tone control circuits are tapped so as to achieve a good 'loudness' feel.
Dennis
Pacing the cage...
Wow, great information. One more question: which one would be best for the verticle control on a scope?
Eric
Eric
The Villages, FL
Linear.
Dennis
Pacing the cage...
Thanks Dennis
Eric
The Villages, FL
There are currently 1564 online users. [Complete List]
» 2 Member(s) | 1562 Guest(s)
