48-1262 loop antenna
Good morning, all
My project does not have a loop antenna for receiving. At some point in its 65 years, someone removed it, and I am sure this is not a new issue.
Since I will have to make one, could someone post a photo of what it looks like with dimensions of the frame, size of wire, and how many turns. The two fragments of wire that I found appears to be thin copper covered with cloth. A source for wire would be nice, too.
KE5YUM
I found what I was looking for. Thanks. Terry
Mike, This is just a thought, the are on the coil where the verdigris (green oxidation is) I wonder if that is where ...Arran — 06:32 PM
Mike; I've made a one or two spiders by using some card stock, and a razor blade, it took more then one try but they ...Arran — 05:48 PM
Philco 91 Restore Code ??
I wondered about that. Wish there was some place local to get this stuff.dconant — 04:20 PM
Philco 89 indicator light.
Bending the lamp bracket (moving the lamp, that is) can possibly change the shape of the pointer a bit, but not its loca...morzh — 04:01 PM
Because the usable power rating of it hen is (3,200/20,000)*25W= 4W. Maybe a tad more due to the mass, but not much. Yo...morzh — 03:59 PM
Thank you Dan, that was the trick. I kept trying to rebend the lamp bracket but that wasn't doing anything to help.Jim Dutridge — 02:18 PM
20K 25 watt. I thought it was a 20 watt at first.dconant — 01:37 PM
My Philco 37-116 Restore
Nah, too much and not that important.morzh — 01:33 PM
What's the full value of that resistor?morzh — 01:31 PM
Been running the radio for three hours now. The power transformer has settled out at 140 degrees. The filter choke is ab...dconant — 12:38 PM
There are currently 5993 online users. [Complete List]
» 1 Member(s) | 5992 Guest(s)
