Philco 90 question
I have a 90 chassis, the one with a single '47 output tube. I've been recapping this thing, and it's coming along pretty well, but there's one odd thing that I've noticed.
I keep having trouble with the '24 IF amp. Every once in a while it dies until I tap on it (the original one had an intermittent short in it, if it died and I tapped on it, it would come back, but I could see it arcing inside). What is interesting is, when the tube dies, or when I remove it completely, I can still hear the tuned in station in the speaker, although the volume control has no effect. I've tracked the signal paths and I find that all the bypass caps in the signal paths have already been replaced.
Both of the shields are missing. I have fashioned a shield around the IF amp, which seems to be very touchy, and breaks into oscillation at the drop of a hat, and this cleared up the oscillations.
Is it possible that I am going to have to locate the original shields in order to keep this 'ghost' signal out? I would not worry too much about it, but I'm thinking it may be out of phase and therefor cancelling some of the signal.
TIA
Someone here once mentioned someone else who makes shields for Philcos. Pretty close looking to those original ones.
Are you saying that the shield makes the IF work normally and it no longer dies? Or you just mixed the two together?
The tube still dies on occasion, it just no longer throws the radio into oscillation. Time to order some more '24's.
Don't suppose you remember who it was that makes those shields?
The gentleman's name is Chuck Paci; he may be reached at cpaci1 at verizon dot net. He does not make the round shields, but he does make the large shields that fit over multiple tubes in Philco 70, 90, 112 and a few others.
Thanks, Ron. I'll contact him. Those are the ones I'm looking for.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
