Philco 39-55 help
Radio working. Replaced all caps. Radio still working, for 2 to 3 weeks, then low volume. Discovered missing voltage in power supply. Top of C42 has 350v but bottom of C42 at secondary CT has only a few volts minus. Transformer V and R checks ok. Resistor 41 checks ok. Field coil 43 ok. What happened? Also tried replacing C42 again but no help. Thanks for any suggestions.
Hi oldtimer
Assuming you are measuring from point to ground, what you are describing is normal for condenser (42). The positive side of that electrolytic will measure around 350 VDC; the negative lead should read a fairly small negative voltage, on the order of 10 to 20 volts.
Time to check tubes. The 6Q7G may be suspect?
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
