37-610 in a 38-9 cabinet cabinet restoration
Well after 5 hours of sanding shes almost ready for lacquer...
[Image: http://i1095.photobucket.com/albums/i474...cb813f.jpg]
[Image: http://i1095.photobucket.com/albums/i474...6fe12a.jpg]
[Image: http://i1095.photobucket.com/albums/i474...15d98d.jpg]
[Image: http://i1095.photobucket.com/albums/i474...9af81c.jpg]
[Image: http://i1095.photobucket.com/albums/i474...772caf.jpg]
Didnt use any stripper?
Did you sand by hand?
Going to use spray toner? Stain?
Looks good.
Tim
Used a electric hand sander 80 grit paper went over it following the different grains in the wood,being careful to just take the lacquer off to bare wood will go over it with fine paper next apply some light stain to the bottom and the strip just at the top. Then spray Lacquer it all over..Did it the same way to the radio(except for a slightly lighter stain will go on mine) I gave to my Sister..here's a pic of hers
[Image: http://i1095.photobucket.com/albums/i474...IM1613.jpg]
I would highly recommend that you use a chemical stripper next time rather then a sander, there isn't much meat to the veneer all it takes is one slip up and you've burned right through it.
I have a Philco 620 where someone used a an electric disk sander on it, not only are there a bunch of swirl marks but they all but ruined the molding on the front panel. Unfortunately the only way to repair the swirl marks is to reveneer the front panel, they are too deep to sand out, the moldings I'm not sure what to do with.[/u]
Put the decal on and 2 coats of lacquer so far.
[Image: http://i1095.photobucket.com/albums/i474...e1ef3d.jpg]
[Image: http://i1095.photobucket.com/albums/i474...8f034a.jpg]
[Image: http://i1095.photobucket.com/albums/i474...36d09c.jpg]
I can even see you in this photo Icon_smile
Got it back together today and it sounds great!!,but have some tweaking to do.Also awaiting the correct grill cloth.
[Image: http://i1095.photobucket.com/albums/i474...8c3857.jpg]
[Image: http://i1095.photobucket.com/albums/i474...f068d4.jpg]
[Image: http://i1095.photobucket.com/albums/i474...f19110.jpg]
CDs go well together with it Icon_lol
Gee Thanks....
Im so glad I took the time to post the pictures I think it will be a Long time before I make that mistake here again.
Which mistake was that?
I like it.Icon_biggrin
Looking good!
Nice job!
Tim
Philco 91 code 221
I have quite a red face! Thanks for the replies. It turns out that I was the cause of the trouble as suggested. It was a...Philconut — 10:30 PM
Thank you Arran for the advice on the speaker, I will certainly give them a try. There is one tear in the speaker and a ...osanders0311 — 10:17 PM
New find. 91X code 225
Cabinet goes fast when you don’t have to refinish most of it. All but the front of the pedestal got a treatment with How...pdieten — 09:26 PM
That's the Philco rf trap in a foreign radio. Resonant somewhere around the IF, it's a short to ground. You can just rep...RodB — 08:10 PM
I can't believe I missed this little critter when replacing the electrolytics. Wasn't much of him left, he crumbled wh...klondike98 — 06:39 PM
Thx Richard. Arran, the 0.02 caps in mine are also 100v. As I mentioned the original paper tube is just a little small...klondike98 — 01:02 PM
Nice job there. A very distinguished looking radio. Would like to see a photo when done with added light. Paul B.Paul Philco322 — 12:27 PM
Thanks all. Yeah, I was motivated to do this one and they're generally easy to work on. I don't do a lot of early-'30s...pdieten — 10:22 AM
Hello Bob, What nice looking set it looks like a Emerson that I have you did great job with the two Electrolytic cans ....radiorich — 02:04 AM
Hello Paul, Well, done it looks great ! Sincerely Richardradiorich — 01:55 AM
