  • 1 Vote(s) - 2 Average
Phono speed selector knob won't turn shaft
        7/26/13 Hi all. I'm restoring a 53-1750 radio/phonograph console.
The phonograph speed selector dial/knob just spins on the shaft.
The shaft is a semicircle shape while the hole in the bottom of the knob is circular. Am I missing some part or some insert that might go on the shaft or perhaps inside the knob that allows the knob to grab the shaft?? Doesn't seem like anything is broken. Thanks,
Mike
It looks like you might be missing the spring steel insert which fits in the slots across the hole in the knob. This is a thin leaf spring which puts pressure on the flat of the shaft and prevents the knob from turning on the shaft.
It might have come loose when you removed the knob. If its lost, you probably can fabricate a workable replacement from thin sheet metal.
I'm afraid it's worse than that. That's a split shaft, and one half of it is gone. Replacing the spring clip in the knob may help temporarily, but the other half of that shaft will break off before long because of the added torque against it because it's other half is gone. Look into having a new shaft fabricated. It shouldn't be too difficult, as long as you can get the old one out. I've even done a couple of these myself.
I wondered if the shaft was split, or just missing the insert - and unfortunately, looks like you're both right. Crapola !! I'm gonna have to have new shaft made and then make some kind of metal insert to go on the new shaft - so it can lock into the knob. Thanks people, I appreciate the help.
Cheers,
Mike
I just used a strong magnifier to examine the (alleged) broken shaft -- and realize it is not cracked or broken. Looks like it was designed with a D shape (or semicircle) design in order for a retainer to be able to hold on to the flat side of it. I've since looked at someone elses 53-1750 and it has the same D shaped shaft. I believe it is just missing the metal clip/retainer -- which are not available -- so I'm gonna get a thin piece of steel and see if I can bend one into the shape it needs to be for this to work. Thanks
Mike
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2349 online users. [Complete List]
» 2 Member(s) | 2347 Guest(s)
