AVC Live for Zenith T/O B600 ???
I am getting ready to do an alignmnet on my Zenith T/O B600 (same chassis as A600, Ch. 6A40). Can someone tell me where to hook up the positive and negative leads on my VTVM so I can measure AVC line voltage? Schematic is here:
http://www.adrive.com/public/3yck9R/Zeni...Color).pdf
Thanks!
- Geoff
Connect your VTVM probe to the junction of R19 and R20. This is the output of the detector rectifier which supplies the AVC voltage, isolated by the 47K resistor R19. This point should connect to the Phono-Radio switch M10. Ground connection should connect to B- ( negative of filter caps). The AVC voltage is negative, so set your VTVM accordingly.
KEEP IN MIND that the B- circuit ground is connected to one side of the AC line so use an isolation transformer, otherwise the case of your VTVM may be hot with 120 VAC. If you have a battery powered DVM, this may be a better choice as it is battery powered and more likely isolated with a plastic case.
Perfect, thanks!
Yes, I have an isolation transformer.
- Geoff
I know I keep telling this to everyone and by now have become redundant, but: Geoff, do check your isolation xfmer isolation, do not trust labels. Mainly, take the meter and check the continuity between both output wires and the Earth GND. Should not be any.
Philco Model 249 made in England
Gary - Thanks for responding!  I hadn't actually taken possession of it at the time of my post but since you said it was...fklown — 03:32 PM
Philco model 40-100
Marion; Replacing volume controls was something some service shops did in years gone by to make a little extra profit...Arran — 03:24 PM
Welcome to the Phorum, fklown!  That's one heck of a Philco 'yardstick' you've got there!  Could you possibly post a clo...GarySP — 03:19 PM
Philco model 40-100
Arran, Thank you so much for your assistance and the link to the fleabay listing! They say a picture is worth a thousan...mhamby — 01:43 PM
I wonder if anyone has any information or experience with this model.  My internet searches are coming up with nothing. ...fklown — 11:40 AM
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
There are currently 691 online users. [Complete List]
» 2 Member(s) | 689 Guest(s)
