Dead Tube Tester
Well, my old Knight Tube Tester died on me a few days back. Was testing some tubes when it started to act erratic and then the needle went all the way to zero and stayed there. Tubes quit lighting on it and even the lights on the tester dimmed and started to flicker. So, it appears I will be on the look for a new tester in the near future. I want to find one that does all the tubes from the 20s clear up through the late compactrons if possible. What make would work the best and what prices should I expect to see?
Jayce,
Moved this topic here for more exposure.
Chuck
Jayce
The way you described it die, it should be something potentially easily repairable. Sounds like some bad contact.
Should be a whole lot easier to diagnose than a radio!
Unless it is an excuse to buy a Hickok 539 Icon_lol
I am wondering if it can be repaired. Oddly, the radio guys I know around here will not even try to repair a tester when something goes wrong with it, so thought once one was dead that was it. Of course of the transformer in mine died...
Jayce
You troubleshoot radios, and those are an order of magnitude more complex than any tube tester. Give it a shot, what do you got to lose?
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2351 online users. [Complete List]
» 2 Member(s) | 2349 Guest(s)
