Speaker / cabinet Vibration
Threads: 37
City: St Louis MO USA
Philco 42-380 has been recapped and resistors replaced but there is a lot of speaker vibration. The bass and treble controls work fine as does the volume control. Any suggestions or ideas for a cause and a solution.
Threads: 573
What is the "speaker vibration"? Mechanical?
Maybe it is just loose? ???
Threads: 37
I have removed the the speaker and put it back in and all hardware is snug. The vibration remains.
Threads: 573
I mean, how does it manifest itself? Sound, or the cabinet walking all over the floor, or...? The very word "vibration" does not tell much. The sound the speaker makes is itself a vibration.
Can you describe it?
Threads: 37
As I turn the volume up the vibration begins and it is most apparent when music is being played. I adjust the bass and treble and the vibration / distortion is less but persists. It is sound not rattling the cabinet is stable and is sitting on carpet.
(This post was last modified: 05-11-2013, 09:37 PM by Ronin61.)
Threads: 573
I think I know what you are describing.
I would say check your decoupling caps but you said you have replaced them.
Output Tubes?
Also: have you checked that your output transformer is good all the way? From the centertap to each end? Are teh voltages on both tubes anodes (plates) correct?
Threads: 37
Great advice I will check those things and post my results.
Threads: 37
Threads: 573
And the last thing (not likely but) - the speaker itself. Just for giggles if you have a similar speaker, you might connnect it and see if the same thing is happening.
First if the speaker has the transformer attached you will be eliminating both at the same time, and then if it shows improvement, you can then try to see which one of the two is the culprit.
Threads: 242
City: West Bend, Wisconsin
I had a similar vibration problem on my 48-1253. By mid volume, the vibration was very noticeable. It turned out there were some teeny tiny little round moth holes in the speaker cone. Once I sealed those up with liquid tape, the vibration stopped. Not saying that's the case with Ronin61's set, though.
Threads: 268
Give the cone a good looking over. Make sure that the paper is glued down at it's edges. At the frame and the voice coil.
Threads: 18
I once found a loose cabinet seam in a vintage Altec speaker which sounded like a bad driver to me and was disproved by swapping out the driver. Couldn't tell from outside and damage probably ocurred when it was shipped to me.
Anyway I patched up the seam and put reinforcement blocks on all four corners, and did the same to its mate. Fixed!
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM |
Arran,
Thanks for checking you manuals.
I appreciate that. Let me know what you find.
PhilPdouglaski — 08:46 AM |
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM |
Philco model 40-100
Greetings;
Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM |
Philco model 40-100
Greetings;
I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM |
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM |
Hello, Richard
the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM |
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM |
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM |
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM |
There are currently 2349 online users. [Complete List] » 2 Member(s) | 2347 Guest(s)
