How many different cabinet styles for 37-630?
Ok I am new to this old radio stuff but want to know some info on my Philco 37-630 which I bought for $20 and want to get it to look and play like new. So I was looking at all the old radio sites and collections and could not find a cabinet that looks like mine. I see lots of 37-630's but with a different style. My question is how many different cabinet styles did Philco make for the 37-630? On the inside there is a paper label which has the part number 102561===final insp. 122031 and run number which I can't make out. Thanks for any info. Dennis
Dennis
You have a 37-630MX, cabinet no. 10256A. Introduced mid-season 1937 (January '37).
The 37-630 was also available as a table model (37-630T) and two slightly different "X" console models (37-630X). Yours is probably the least often seen of the four.
Interesting top. What that patterned after the Boston Garden BB court????8)
Philco Parquet!
thank you guys for the info on my radio I will post pictures when I get it all done it is gonna look sweet.
Nice radio should be a keeper when you are finished with her. Take your time with it and keep us updated...
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
Philco 40-120C Restoration
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
Amen to that! Every time I think I’ve captured them all, I realize that there’s another error. My goal is to finish with...jrblasde — 07:00 PM
There are currently 4766 online users. [Complete List]
» 1 Member(s) | 4765 Guest(s)
