Philco 41-221 Oscillator Adjustment?
I am helping a friend with his Philco 41-221. It has been recapped by a previous repairman. The radio frequency on the dial is way off. Where is the adjustment for changing the oscillator frequency so that it agrees with the dial pointer.
Also, at the very high end of the dial there is oscillation or motorgboating. The electrolytic capacitors and paper capacitors have been changed.
Thank you for your suggestions.
Oscar
nv3g
The loctal tubes are notorious for developing dark oxide corrosion on the pins, resulting in intermittent contact with the socket. It is usually very hard to remove.
I have had the best luck with thin strips of 400 grit wet or dry sandpaper. Loop the strip around each pin and pull it back and forth until the pin is shiny and clean. To prevent future corrosion, apply a thin coating of silicone dielectric compound to each pin. The silicone is available in small tubes at auto parts stores and is used for waterproofing electrical connectors and spark plug terminals.
Agree with all.
You can also beg an old currette or two from your dentist or hyguenist. Still will be plenty good enough to scrape loctal pins and the tools also "goes around corners" to get the inside edges. If the sockets are nasty too, deoxit and plunger like stabs with a thin toothpick usually helps a lot. Remember to bend toward the nipple on the base of loctals to remove them from sockets without harm.
Oscar, if you can get a copy of the Philco service information for this set, it shows where the trimmer for the LF oscillator is located (on back of the chassis).
Nostalgia Air is currently down, but you can also find it here:
http://audiophool.com/Misc/philco_41-221.djvu
(requires IrfanView or other compatible DjVu file viewer)
N.A. back up for the moment anyway.
Schematic here as alternative:
http://www.nostalgiaair.org/PagesByModel...013394.pdf
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2358 online users. [Complete List]
» 2 Member(s) | 2356 Guest(s)
