How to deal with blush
Well, I should have known it was too humid to spray finish coat lacquer on today and now I have some blush to take care of. It's on the final step after I toned the "cheap" wood with Mohawk toner to darken it. What do you say I should do now? I don't want to have to sand and then retone several small areas including the grille bars on my Philco 38-1 console.
First of all wait for a day and see if it goes away.
Sounds good to me. I'm in no special hurry.... I've had to wait to get started on this cabinet since mid-February!!!
Mohawk No Blush Plus will make that blushing disappear like magic.
[Image: http://woodfinisherssource.com/cart/imag...3-0475.jpg]
Great to have if you spray any lacquer anytime the weather is humid.
Going over it lightly with 0000 steel wool will remove it.
In NC I encounter this often.
Philco 40-120C Restoration
Hello David, that is great news about the tubes source being local ! Sounds like you got good start on the radio . ...radiorich — 09:41 AM
Mike; I've only run into a speaker with an open filed coil twice, and they were on newer speakers from the 1940s. One ...Arran — 12:48 AM
Arran Yes, this is my plan for now and what do I got to lose, this is not even the speaker from this radio, but one o...morzh — 10:44 PM
Mike;  I would unwrap the field coil, and see if maybe there a break near one of the ends, like where the coil wire att...Arran — 10:23 PM
...and this is what I did. I fed a little LT into the screwholes with a small brush, and a little on the rim next to the...morzh — 09:52 PM
I combined the two 40-120C threads together as we like to keep the discussion of the same radio together. It helps with...klondike98 — 09:36 PM
Philco 40-120C Weak, Distorted Ouput
Just checked were I buy tubes price is four dollars. So living in Florid we have a local source for tubes. David    David — 09:14 PM
The higher voltage may be due to higher mains voltage. My mains run 120-125AC when the set was new mains would be 110-11...David — 09:09 PM
Thank you for your reply. I pulled a speaker from a Philco 41-221 and received the same result. I used a signal tracer t...bluecap — 08:45 PM
Have you tried a different speaker? How did you trace the distortion? How do you know it is weak? What is the reference?...morzh — 08:33 PM
There are currently 2830 online users. [Complete List]
» 1 Member(s) | 2829 Guest(s)
