Philco 37-116 Auto Tuning
I am working on a 37-116 with auto tuning. The fine and speed knobs turn the tuning cap fine but the dial doesn't move. The auto tuning mechanism turns the dial fine but there is no connection to the cap.
In looking on Chuck's site and the service bulletin it looks as if there is a small pin (#22) that connects the 2 parts. I have looked all around the outside of the vernier drive housing and I can't find a pin. What am I missing?
Do you have any suggestions for me about how to proceed with this repair? I would sincerely appreciate any advice before I try to tear things apart.
Don Meyers
In looking further I have found that the autotuning mechanism is driven by a small gear and pinion and the set screw wasn't holding. The center chassis mounting rubber grommets are badly worn and need replacing. The worn grommets cause the chassis to sag and the tuning cap gets out of alignment and caused the mechanism to turn with difficulty.
Does anyone know where I can get 3 of these special grommets?
Don
Just an update on the grommets. I found a link on Philco Repair Bench to Ed's Radio and found all the grommets I need.
http://www.renovatedradios.com/parts.html
Don
Thanks Don, I have never torn the magnetic tuning models apart even though I have about 7 of them so I couldn't comment/help you. It's nice to know the grommets are available I also know the end of the shaft gets worn a bit and you need to dress it up and relube it (Chucks site). I have the 38-116 and 38-690 but one of these days I need to get a 37-116 also.
Need Help to ID this radio 11 tube Philco
I did R73 RCA. It has a phenolic board with all stuff mounted on it. And the wiring is deep under everything including ...morzh — 10:37 AM
48-482 rear panel help
Hi Keith, here is an article that covers different FM detector circuits including a section on the theory and alignment ...462ron — 08:26 AM
Well then Dan I guess this old man’s memory wasn’t too foggy :lolno: although I couldn’t remember where I saw that upgra...462ron — 08:08 AM
Fortunately, I did not have to do much to my GE S-22 (RCA R7A) Almost all caps and the 2 audio transformers packed into...MrFixr55 — 07:44 AM
Yup Arran is correct it is missing the pushbutton covers. I don't know where they all go but it's a common issue on this...Radioroslyn — 06:48 AM
I also have one of these, again it never had a back, and no trace of one. I have been told that the pushbuttons used to ...Arran — 03:29 AM
Thanks Joseph. Hope you get to restore your 48-482 before too long!keithchip — 02:12 AM
RCAs ain't no cake either.morzh — 10:32 PM
After a couple of days worth of troubleshooting my signal generator, I gave up. The oscilloscope still worked fine, so I...jrblasde — 09:51 PM
Yes, I can confirm. I bought one (haven’t restored it yet) which didn’t have a back panel.jrblasde — 09:37 PM
