Threads: 147
City: Elko,MN.
Well guy's, I brought another one home.
As if I have room. Couldn't resist.
Got a really nice virgin 37-675 from a person that was moving and did not have room.
THing has not been plugged in for years.
Cabinet was professionally re-finished years ago. Lots of different veneers in this one.
Must have been the last of the legged models.
Has 12 tubes.
Brought it home and checked the chassis out for obvious problems, and plugged it in to my variac.
After a few minutes of cranking the variac up, I got audio and faint signal.
Very promising.
Only problem I see right away is that the tuning condensor is not turning with the control knob.
Looks like there is a loose or disengaged gear on the front of the shaft.
Anyone have a good diagram of how the tuning mechanism is supposed to work on this model?
I think I will re-cap,check resistors and tubes and see what happens.
Not a bad find for $25.00.
Input or suggestions?
murf
Threads: 573
I suspect the tuning mechanism is the same as in 37-116. The gear itself will not slip, but there is the coupling that connects the output shaft of that whole concoction with the shaft of the cap. The cap is held by two set screws of that coupling and so is the shaft of the gear. Pretty straightforward, you just have to look what is slipping. You will have to pull out the chassis, but have to do that anyway.
Good luck and congrats, for 25 bucks this is a gift.
Threads: 268
Have seen that coupler fall apart too.
Great deal for $25!!!
Threads: 147
City: Elko,MN.
Have not taken it apart yet, but it looks like there are a couple gears towards the front of the shaft that are slipping on the shaft.
Wonder if they are stripped? Looks like a serrated shaft.
Probably see if I can fix that before I dig into the rest.
Anyone know where I can get parts for the tuning mechanism if I need them?
THanks for the replies guy's.
murf
(This post was last modified: 06-05-2013, 10:34 PM by murf.)
Threads: 573
You can try to use some special epoxy to secure the cogwheels. And the lubricate it well with lithium grease to keep the torque acceptable.
Threads: 147
City: Elko,MN.
Looks like the front portion of the shaft has the splines wor out as well as the 2 small gears that engage it.
WHy do they use 2 gears back to back on this mechanism?
I think I will need to look for the front end assembly with the gears and the shaft to the point where it attaches to the rubber disc. Maybe even farther up the shaft to where it connects to the tuner assembly?
Anybody know what models use this configuration?
Maybe someone has a junk chassis laying around that I could steal parts off of?
Have to put it aside for a while and see if I can find parts.
I am supposed to pick up a 38-3xx nest week that I plan on using for salvage, depending on how it looks when I get it home.
Any similarities between the 2 chassis tuner mechanism's?
murf
Threads: 92
City: Clayton, NC
Threads: 268
It's called an anti-backlash gear. There is also a small spring between the two gears. It puts tension between the two sets of teeth so that there isn't any play between it and the gear it's mated to. If you've take it apart be sure to add a little to the two gear before assembly.
Threads: 147
City: Elko,MN.
Thanks Terry,
Unfortunately the springs are missing on the 2 gears.
Might have to try to find another similar mechanism and steel some parts.
HAve a great day.
murf
murf Wrote:Anyone know where I can get parts for the tuning mechanism if I need them?
The following Philcos all use the same basic assembly:
37-9
37-10
37-11
37-675 De Luxe
37-116 De Luxe
37-690
38-1
38-2
38-3
38-116
38-690
Note that the 1938 models only use 2 lamps to light up the preset tabs while the 1937 models use 4, but the mechanisms are otherwise identical.
Threads: 268
You mean 37-116 code 122. This Deluxe is a little confusing.
Threads: 147
City: Elko,MN.
Hi guy's,
Getting alot of useful info here.
Mine is not the deluxe model, so it does not have the tuning dial with the presets. Just the standard Philco round dial .
Looks like there were about 3 versions of the 37-675 model.
Would be nice to find the front tuner assembly from one of the models Ron mentioned.Looks like there were many with the same assembly.
Then I wouldn't have to steel one off another that might be better left whole.
murf
Threads: 40
City: McPherson, KS
Hey Ron,
The dial lamps on my 38-1 do not light up the preset tabs.
Art
The Magnetic Tuning Off-On switch has a habit of going bad, where it will turn the AFC circuitry (Magnetic Tuning) off and on, but will not turn the lamps off and on. If cleaning does not help, a new switch is the only cure.
Threads: 147
City: Elko,MN.
Well, thought I had the parts to replace mine, but alas, upon looking close at it the 38-3xx has a different assembly due to the station preset buttons.
Guess I will have to see if I can fix my original by gluing the gears on.
Guess the antibacklash springs would not do me any good either.
Did hook the 38-3xx up to my variac and I did get some activity as far as tubes etc., but no real reception.
Might have to just put it in the to do pile that is getting too big.
murf
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM |
Arran,
Thanks for checking you manuals.
I appreciate that. Let me know what you find.
PhilPdouglaski — 08:46 AM |
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM |
Philco model 40-100
Greetings;
Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM |
Philco model 40-100
Greetings;
I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM |
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM |
Hello, Richard
the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM |
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM |
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM |
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM |
There are currently 2347 online users. [Complete List] » 2 Member(s) | 2345 Guest(s)
