Model 20 mystery wire?
I was looking under the chassis of a Model 20 today and noticed an extra black wire coming out of the power transformer. It is connected to the tapped power resistor and is the only wire from the transformer, all the other connections are made by 12 solder lug terminals.
Certainly looks like an afterthought and does not seem to appear on any of the published schematics, as all the transformer terminals are numbered 1 to 12.
Whats going on here? The wire looks original.
I thought the same thing when I was recapping my model 20. I have the same wire coming out of a small hole in the phenolic board and going to the B-C resistor. It's also the only wire that appears to be rubber insulated. All the rest of the wiring on my chassis is braided cloth insulated. I'd sure like to know as well! Take care. Gary
Faraday shield, perhaps? Does it connect to terminal 3 of the tapped power resistor?
Often a Faraday shield, when incorporated, is simply wedged into the laminations or mounting screws somehow and you never see it. This could be an external connection for better grounding.
No, it goes to terminal 2, which is the tap on the resistor for the grid bias of the 27 and 71A audio stages.
Faraday shield would be a good choice if it went directly to chassis ground terminal 3, but it does not.
Perhaps it is the connection to the center tap of the 2.5V filament winding? The schematic shows the center tap of the HV winding and the 2.5V winding both connected to terminal 6. Maybe they separated them, but I don't know why as they both connect to the same terminal 2 of the resistor.
Philco 91 code 221
Philco 91 code 221
Philco 91 code 221
Hello Keith, great news !! Sincerely Richardradiorich — 02:14 AM
Finally, got the antenna fixed (repaired some broken wires) and have the radio playing. I've got four different schemat...keith49vj3 — 09:38 PM
Bob, Nice radio.  I’ve not seen one before.  Keep us updated!Joe Rossi — 07:56 PM
Phioco 90 Power Transformer Wire Colors
Thanks for adding that information.klondike98 — 06:09 PM
Although I have used this site as a resource for a number of years this is my first post.   I am restoring a Model 90 si...vincer — 05:02 PM
My collection presentation
There is a complete instruction how to solve your problem. One piece of advice - be careful with the low-voltage capacit...Vlad95 — 09:32 AM
There are currently 737 online users. [Complete List]
» 2 Member(s) | 735 Guest(s)
