38-1 cabinet progress
After several weeks of delay..cold garage (where I have to do my cabinet work) due to unusual spring, other chores, etc. etc...I'm finally making progress on this cabinet I hauled home from Indiana in February. Had to reglue a little bit of veneer and I finally have it stripped. This is one BIG cabinet to redo. Toning and lacquering is next. I THINK it will be nice when done.
Looks good already. It's in a decent shape!
Icon_thumbup
Very nice wood and a nice job stripping. Can't wait to see the finished product.
Jerry
Wondering about this; there appears to be some swivel "keepers" on the back edges of this cabinet. Should I assume it had a cover on most if not all the back originally?
You assume correctly, sir: Like the 38-116, 38-690 and others, the 38-1 originally had a (ventilated) back.
Thanks Ron. I was wondering if somebody in the past had added something aftermarket. 5 of the "keepers" are still good. I have some large backing material I might consider duplicating an original if I had a good picture to go by. I don't think it would be terribly difficult to make a few more "keepers" to round out their total number. Obviously that's not real critical but it might be fun to try that challenge sometime.
Art, Eddie Brimer on the alternate forum has had a template made for reproducing these. A while back he was asking if people were interested in purchasing reproductions. He also had a silk screen made for adding the graphics that are on the back cover.
Jerry
Jerry,
Thanks. I sent Eddie a PM to see what the situation is now. I was looking through the parts list in Riders for this radio and discovered the back cover was listed with this part number; 27-8865. Would be nice to find one. Icon_smile I'm dreaming of course Icon_lol
Calling it "done." Sounds great; looks pretty good I think. It's obvious the different style in 1938 Philco and 1938 Zenith in this view. Proud to have the 38-1 on my console row.
Nice looking row!
Thanks.
Art Beautiful job well done! Those are some nice console radios........I would like to hear them sing !!!
John,
Here the singers are! Soprano, Alto, Tenor, Bass...or is it Alto, Tenor, Soprano, Bass...or is it Alto, Bass, Tenor, Soprano...or is it..........
Should I have them all one at one time? Hmmmmm, interesting thought.
Where is the H-87??? Thought you had one.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1037 online users. [Complete List]
» 2 Member(s) | 1035 Guest(s)
