Philco 70 1929 Cabinet
I am trying to "restore" my philco lowboy cabinet; it is really dry mahogany and I did not know if I should just use an oil on it or what .
Any suggestions?
Hi George and welcome to the phourm!
Just to be clear on your set it isn't a model 70 as it didn't come out till 1931. It's probably a model 87 or 95 but would have to see the back of the set to tell which one it is. I don't know if you know it or not but the legs on your cabinet have been removed. It should stand a bit taller. Here's a pic of it: http://www.philcoradio.com/gallery/1929c.htm#d
I have a model 87 and the 95 both are good set for 1929 technology!
I like to use GoJo pumice free hand cleaner to get all the old oil and wax off first. Then, Howard's Restore-a-Finish it it needs a little color. Finally, Howard's Feed'n Wax (orange oil + beeswax).
Here's a Philco 70 lowboy from 1931 for comparison.
[Image: http://farm3.staticflickr.com/2181/41215...db21_z.jpg]
Thanks everyone! I will try the products you recommend for the finish. I am also trying to find a set of legs for my radio since they have been removed.
George
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
There are currently 589 online users. [Complete List]
» 1 Member(s) | 588 Guest(s)
