Newbie, Philco H865
Hello all, new to the "Phorum." Not sure if this is the right thread section if not bump it to the right one. But over the weekend I picked up a record console of Craigslist. Was trying to look for an Owners manual for it or any kind of info. Its a Philco Ford H865. Has the AM/FM, 8 Track, and Record player. Anyone know what year this is from? Also I need to replace the needle for it as it was broken. Any help would be appreciated. Thanks!
"H" indicates 1960, however I do not show H865 in any of my literature. Console stereos of the era normally had 5 digit model numbers. A letter followed by 4 numbers, possibly a couple of additional letters for cabinet finish. Eight track indicates something later than 1960. Take another look.
A needle or cartridge number will help finding a replacement. The changer could be a VM, Glaser-Steers or BSR. Without an accurate model #, a photo of the changer will help.
Don
I did find the player is a BSR C123-B1. I have the player part at a shop trying to find a cartridge and needle for it. I also found a tonearm on ebay that matches if he cant find anything
This is the sticker on the back of the unit
It appears to be a Canadian number. I have no information on Canadian Philcos. Perhaps others can help.
Excited. The shop I took it to found a cartridge and needle for it! He'll order it tomorrow.
Rogers Majestic R-646
Vlad; I was just reminded of something else, I'm not sure why but many Rogers built sets do seem to have open primari...Arran — 04:40 PM
Thanks RpdB I don't think there's much difference with interstage transformers of different models other than dimersion...Vlad95 — 03:27 PM
Vlad; I looks like your set has the same problem that mine did, both a bad output transformer, and a bad audio inters...Arran — 03:21 PM
Ouch! Not often the secondary takes a hit. Wish there was a better solution. I have a good interstage transformer but it...RodB — 02:59 PM
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
There are currently 1037 online users. [Complete List]
» 4 Member(s) | 1033 Guest(s)
AvatarAvatarAvatarAvatar
