What 2 original stains are these?
I"m restoring my early 1936 Philco model 60 and what to make the cabinet look like these 2 color stains. What would you guys think would be the closest stains to match?
Stains were not used for Philco production, toning lacquers were used and are now available from Mohawk ( http://www.mohawk-finishing.com/catalog_browse.asp ) Here's a previous Phorum thread that might be helpful http://philcoradio.com/phorum/showthread...=60B+color . When some of the more experienced folks read your question they will likely have some more specific help for you.
As Bob (klondike98 ) said, you should use Mohawk toning lacquer - you will never get the right "look" from stains.
Also keep in mind the radio in your third photo was refinished improperly - it is too light overall.
Here is what I suggest - Medium Brown Walnut and Perfect Brown, both the "Ultra Classic" (dye) toners from Mohawk.
http://www.woodfinishersstore.com/mohawk...sic-toner/
This illustration might help.
[Image: http://i326.photobucket.com/albums/k420/...g~original]
OK thank you Ron, I will post pictures when I get done. Also Ron what should I use to make it nice and shiny after the toner?
Gloss lacquer. Your results will depend on the quality of your filler application. Rubbing out the lacquer is another story. They (the factory) didn't have time to rub them out, but they had the finishing down to an art.
+1 what DK said. Icon_thumbup
KK thank you all for the input
New find. 91X code 225
Thanks all. To be honest I don’t know what to make of it being in this cabinet style but I like it a lot. I specifically...pdieten — 12:47 PM
Nice grab! It appears to be a 19X cabinet. This wasn't unusual. Philco often retrofitted to other cabinets as invento...GarySP — 12:32 PM
I would certainly write down step-by-step the progression of disassembly of the works, and probably cuss out the electri...GarySP — 12:18 PM
Nice looking! This annotated schematic from our library shows parts that are slightly different in the early and later ...klondike98 — 11:33 AM
LOL!! Well Arran, if you do dive into it and come across any advice on dealing with accessing components let me know. I...klondike98 — 11:56 PM
Bob and Gary; I have the further complication on the Phillips that they decided to use some 200 volt rated paper caps...Arran — 10:05 PM
Thx Arran & Gary. Yes its super crowded in the chassis and I've debated whether to try to restuff caps or not. I t...klondike98 — 07:40 PM
That's got to be one of the tightest conglomeration of components I've ever seen! I wonder how the line workers felt bu...GarySP — 05:46 PM
Bob; I think that the Phillips was actually manufactured in Canada, though they may have imported many of the compone...Arran — 02:28 PM
I've started replacing the electrolytic caps now. As Arran mentioned, they are housed under a metal strap. Here's a ph...klondike98 — 12:22 PM
