philco 46-1201
hi guys
as i have only done 1 recap set so far which turned out easy no problems and worked (lucky) as i bought a 1201 on ebay guy said it worked but weak ya was crappy. arived in yep pices he refunded me got to keep it. some one else had recaped it . powered it up with veriac no shorts or smoke lights up all tubes light. as i can not pic up any am or fm D**n condo i have to use small am transmitter picks up weak and motor boating with sqeals any one have parts locator list ? it has 2 antanna wires coming from tuner and coil both about 6inc long cut just laying ? and last it has a long sqaure block with three wire on it ?
thanks sam
If you go to the Home page on the site you will see a menu heading for Knowledge Base. Under the pull down there is a further menu item for Schematics. On that page you will see a list - if you dont find your model, further down the page is a list of links where you can find schematics. Many of the schematics include tube and parts layouts. But you are on the right track - you need a schematic at a minimum.
Are you sure you don't mean 46-1201? There is no such thing as a 36-1201.
oops sorry 46-1201 not 36
You can find a schematic for the 46-1201 here: http://www.nostalgiaair.org/Resources/584/M0013584.htm and here http://audiophool.com/Philco.html and here http://www.philcorepairbench.com/schematics.htm .
I changed the title of this thread to 46-1201 to avoid confusion.
hi guys
thanks for info maybe this isn`t a good project to start with. i check all seams ok just need 2 more caps to do. i put transmitter right up to tuner picked up loud had to turn tuner all the way to left untill it stoped hads a slight vibration in sound nothing changes when i tap tubes speaker was repaired bad job of it as it is rock hard half way around it`s oval shaped i left on about 2hr seams ok maybe an alignment as transmitter is at 1600 not 500
thanks ron
1600 - 910 = 690 At that spot on the dial you would be able to hear a strong 1600 KHz signal. 500 (more like 540 at the bottom of the dial) would be way off. I see no adjustment for the bottom end. Are the IF's tuned to the proper frequency?
Need Help to ID this radio 11 tube Philco
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
It is a 16B tombstone.morzh — 06:13 PM
David - sorry, I reread your post and finally saw THD - now the % figures make sense. Thanks for explaining. The PSU...EdHolland — 06:06 PM
Hi Everyone, New member but have been reading this for awhile for tips! Vaccum tubes were before my time so bear with ...Ken D. — 06:03 PM
My Philco 37-116 Restore
Thank you MrFixR55, I appreciate your comments very much. I do not detect much hum if any so I will be staying with the ...dconant — 05:15 PM
Hi DConant Yes, you can replace chokes with resistors.  You do stand the risk of increased hum.  the solution is to inc...MrFixr55 — 04:23 PM
