Radio back board pins
Hi,
New here and thanks for having me. I was wondering if anyone knew of a supplier of these back board pins. I am restoring a 48-1201 and found only one pin.
Mike
http://i1220.photobucket.com/albums/dd45...33642f.jpg
Welcome to the Phorum! You could post a notice in "Wanted Ads" section. Might also try David Frush at parts2many@aol.com. He has a lot of different types of non-electrical parts. Also take a look at this http://www.renovatedradios.com/parts.html#trimounts . Not exactly the same as pictured but might do the job?
I don't know of a source for them but they used to be called tri clips because of the three legs they have. You may try an auto parts store or an outfit like McMaster-Carr, or one of the outfits that sell restoration bits for vintage cars.
Hey Mike
If you do run into a source for them let us (Phourm) know. The question does come up from time to time.
TNX
Terry N3GTE
Help with Supreme 599
The 300 ohm line adjustment is used to set the primary of the transformer to a nominal voltage for any line voltage from...DaleHCook — 09:22 AM
Philco 37-116 Cabinet Repair
I think Arran is correct about the substrate expansion. I'm going to give the colored wax a try.dconant — 08:11 AM
Hello Guys, What I would do is get  colors of wax filler and fill in the void ! Sincerely Richardradiorich — 12:41 AM
It looks to me like the structure under the veneer may have expanded from humidity cracking the veneer on the surface. W...Arran — 09:42 PM
Iam only getting 4vac out of the tranny For the 80 filament. The line rheostat Looks fine and the tranny is getting 11...daveone23 — 08:45 PM
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
There are currently 691 online users. [Complete List]
» 2 Member(s) | 689 Guest(s)
