48-482 Wood type?
I've started on a 48-482. It's not too bad but I'm going to strip and refinish it. My question is what type of wood is used? In other words, what shade of stain should I use?
Eric
Eric
The Villages, FL
I would go with a light or medium walnut on the main part of the box, the faceplate is darker on all mine
John
Las Vegas, NV USA
John,
Sounds great. I'm going to go with medium walnut. I got lucky with the faceplate. It cleaned up with some Goop hand cleaner. I even got new decals.
Thanks for the help,
Eric
Eric
The Villages, FL
Eric, how did you take the old decals off? Mine are intact but have become rather dark. I'm cleaning the faceplate (which is photofinish I believe) with GOJO and its coming clean but I don't want to get too aggressive to get the decals off.
It is not Photofinish.
Some of them show the natural grain. Some of them have a burl effect painted on under the toner and top coat.
I ended up refinishing the faceplate so the decals were not an issue. Normally I use 0000 steel wool very lightly on the old decals to remove them.
Eric
The Villages, FL
OK thanks. That's what I did on the 42-322 I did but the decals were not on photo finish. Maybe they'll come off ok, if not I'll refinish it.
Don't worry, Bob. It's not photo finish. I used a dark walnut stain.
Eric
The Villages, FL
Oh... OK. It fooled me. Have to take a closer look tomorrow.
Rogers Majestic R-646
Transformers rewind? It's very easy! If you don't have round eyes  8-) Vlad95 — 01:55 PM
Help with Supreme 599
I found a broken wire from the end og the 300 ohm line adjust to the transforner but i dont think its needed. The transf...daveone23 — 11:43 AM
Philco 38-10 Tuning Condenser
RodB I have been using pure Vaseline for a long time for thick lubrication of home radio devices. The main reason is t...Vlad95 — 10:58 AM
Vlad, your comment about Vaseline brought a thought. Does anyone know the long term affect on using silicon grease on t...RodB — 10:34 AM
Arran, didn't notice the specifics for the caps. What's the code going to get me? I'm working on restoring a Philco 50-9...RodB — 10:26 AM
I managed to get the gears lined up and the springs back in. Much easier than it thought. Putting a thin wire down insid...dconant — 09:52 AM
Rod, Mrfixr55 and everyone else thank you very much for all your help with this radio thus far. Today will be more testi...osanders0311 — 09:26 AM
Thanks for the reply Vlad95. I can't even see the balls let along try to remove them. The grounding forks are going to p...dconant — 08:03 AM
Vlad; Yes it's very similar, Motorola obviously wanted to get the most use they could out of the dyes used to stamp o...Arran — 11:18 PM
Rod; I that 27 pf 1 kv capacitor you found a C0G ceramic cap or just a regular ceramic cap? A different topic but I t...Arran — 11:16 PM
There are currently 703 online users. [Complete List]
» 2 Member(s) | 701 Guest(s)
