coil 32 - 1360
Hi All;
I have a coil Philco number 32 - 1360, does anyone know what it came from and or what It does ?? It has a broken wire and I don't want to attempt to fix it till I know more, If possible.. I can ohm it out, but data or schematic data would be helpfull..
THANK YOU Marty
Why not post schematic or link, or at least model number you are working on. And which coil is involved?
Hi All;
I got the coil from "things of the past" as part of my coil order to get the minimum order.. Both Gary and I have no idea what it was part of, I have two others that I don't even have a number for.. Just thought I would ask, If anyone recognized this number.. I didn't want to just completely tear out the wire, If I though I could use it for something.. Same with the other two, I will eventually measure the resistances on the other two, to see if they match anything I have documentation on.. All three were used "Junk" coil forms.. And this one was the only one with a number.. I am very Happy with the Service and what all I got from Gary, He is and was very Helpfull.. I would recemend His site to anyone..
THANK YOU Marty
Hi All;
I found it !! The 32 - 1360 is the Antenna coil for the Model 28 - 29 Philco.. If I am reading the listing for the Model 28 - 29 correctly, its slightly blurry.. I was hoping that if I downloaded enough of them and looked (If they had a listing) I would find it.. Just thought someone would know..
THANK YOU Marty
New Philco Repair Bench
I'm not sure why that wire wasn't covered in the video. I'm pretty sure the 6A8 won't work until that pin is grounded. Y...RodB — 09:47 PM
You'll have to forgive me, I am not sure what you mean.  Can you explain what you are really saying.  If anyone does not...georgetownjohn — 08:05 PM
Those are details better left to the ones who know. Maybe you disconnected the wrong end of the wire.RodB — 06:22 PM
Maybe this is starting to make some sense in my hard head.  Is this why the wire in question was not in the great Ron Ra...georgetownjohn — 04:34 PM
I was correct with the 6A8 pin connection's, 7 and 8 are connected to ground as well as the tube shield (the broken line...RodB — 02:41 PM
What does the dotted line representing that surrounds the tube in the schematic?georgetownjohn — 02:17 PM
Hello John, I have been there either label got lost or was not labeled ! Sincerely Richardradiorich — 02:15 PM
Sorry, it is a Philco 37-640.  Does that help?--Johngeorgetownjohn — 02:14 PM
There are currently 6074 online users. [Complete List]
» 4 Member(s) | 6070 Guest(s)
AvatarAvatarAvatarAvatar
