Help on volume pot
Attached is a link to the Philco 52 schematic. The volume pot appears open. It is a single gang pot item #1 on the schematic. Unfortunately no information on it. Can anyone tell me the value and would that be a linear pot?
Thanks as usual for any help. Jerry
http://www.nostalgiaair.org/PagesByModel...029640.pdf
Because it controls the bias on the IF tube and is fed about 4 mA by the 51K resistor, it should be about 7.5 K Ohms for good control of the IF gain. Linear is OK and wirewound would lessen the shunting of the antenna at high gain.
Thank you Bill, not certain I understand why wire wound would be better but I will see what I can find. Is your comment about wire wound that it supplies a certain amount of inductance? Not smart on this stuff. Right now not a killer only that in circuit it measures very strange and the radio working (no replacement parts installed yet other than e-caps). No volume until 3/4 of the way up on the pot and it jumps on loud. If it is a wire wound I may be able to take it apart and do some good.
Jerry
Jerry,
Volume control should be Philco p/n 5839, which is a 5K wire wound pot per info on Chuck's site:
http://www.philcorepairbench.com/volctl.htm
Carl
Northern Panhandle, WV
Thanks Carl, I will check against the P/n on the back. Chuck's site is amazing, I still haven't discovered all the help on it! Doubt I'm going to find one of those but who knows? I'm using his site now on the bakelite caps, the information I have from N/A is so incomplete, need to order Chuck's nice package, I'm going blind and getting a headache trying to figure things out.Icon_lol
Jerry
Quick update on the existing pot, is has a number on the back. It is "6415F" and looks as though it has perhaps been changed in the past ie crappy solder job.
Original or something someone had at the time?
Jerry
Jerry,
For best performance, you need as much wire up for an antenna as practical, and a good ground.
Chuck
Quote:Thanks Carl, I will check against the P/n on the back. Chuck's site is amazing, I still haven't discovered all the help on it! Doubt I'm going to find one of those but who knows? I'm using his site now on the bakelite caps, the information I have from N/A is so incomplete, need to order Chuck's nice package, I'm going blind and getting a headache trying to figure things out.Icon_lol
Jerry
Chuck's site is wonderful, but beware that some of the info that Philco released on bakelite caps is incorrect. On the obsolete caps, you get referred to a new part number, and the schematic of the cap is shown as a "universal cap", usually with twin caps that are shown connecing pins 1-3 and 1-2. I have run across a couple of bakelites that connect pins 2-3, and the universal cap doesn't display that.. Just pay close attention when you clean out the old cap and check the Philco values against the schematic and you'll be fine.
Road Trip for a Philco 46-480
Good morning, folks! I’ve finished the cabinet and the electrical restoration, and have detailed those in their respecti...jrblasde — 10:56 AM
Arran, Thanks for checking you manuals. I appreciate that. Let me know what you find. PhilPdouglaski — 08:46 AM
I have some car radio service manuals, Riders I think (not to be confused with the big blue binders), so I may see if on...Arran — 01:20 AM
Philco model 40-100
Greetings; Here is an update, I found a listing on fleabay for a similar chassis to yours, and it has a photo of what...Arran — 12:58 AM
Philco model 40-100
Greetings; I think I may have found a clue as to what is missing, from a search I made, there is a rear view of the c...Arran — 12:12 AM
Philco model 40-100
I recently acquired a Philco model 40-100 farm (battery) radio. The radio was in very good condition except the red on f...mhamby — 05:59 PM
Hello, Richard the radio is an AC-2687 Studebaker model. The Philco model is S -5323 and the chassis p/n is S-5523Pdouglaski — 11:52 AM
48-482 rear panel help
The 48-482 is an AC only set as well, featuring a power transformer. While the transformer shouldn’t get “hot”, it is ye...jrblasde — 11:12 AM
I gave a Chrysler/MoPar car radio from 1954, it was made by Philco, and it uses two chassis, one has the power supply an...Arran — 11:06 AM
Hello keithchip. You could make a hardboard back for the set, but make sure you provide plenty of ventilation holes in ...GarySP — 11:04 AM
There are currently 2351 online users. [Complete List]
» 2 Member(s) | 2349 Guest(s)
