Philco 40-145 Cabinet Repair
City: Kentucky
Here is the victim. A Philco 40-145 I picked up at a flea market. The major problem was the wooden surround on the dial. Most of the top was missing. There were also issues with the veneer. Pieces were missing from the top right above the dial, and on both sides. The bottom right was a pretty big chunk that was gone. Also, above each push button, the veneer was gone.
(This post was last modified: 09-12-2013, 05:11 PM by Jamie.)
City: Kentucky
After stripping the cabinet, I started off by gluing a piece of 1/4" x 1/4" inch wood stock onto the dial face. It was fairly soft wood, and the photo shows I have already sanded it into the rough shape needed.
Veneer scraps were cut and glued into the missing areas. I also did the places above each push button and the face of the radio. After the glue dried, 400 grit sandpaper was used to even them up with the surface of the radio.
(This post was last modified: 09-12-2013, 05:20 PM by Jamie.)
City: Kentucky
(This post was last modified: 09-12-2013, 05:30 PM by Jamie.)
City: Kentucky
Ready for toner and clear...
City: Kentucky
All finished and singing a 40's tune! Please ignore the light area on the bottom photo - my camera does that. I assure you, the finish looks fine in real life.
Is it perfect? Nope. But it's good enough for government work. I wish I had used a lighter colored stain on the new wood, but it is what it is. Next time, I'll know better.
You can see how well Timber Mate works. The repairs on the veneer are virtually invisible. I am very pleased with the veneer repairs. As for the wood around the dial? It's the best I could do and I think it came out well. It shows that almost any radio can be fixed.
Threads: 8
City: Central PA
Very nice work and results! Thanks for sharing the process - it's a great way to learn. You've got quite a little beauty there!
So how long was the overall process, you've made it look like it just a few hours...
City: Kentucky
Thanks! Umm.. I bought the radio about 10 days ago.. maybe two weeks. The first photo was taken then. The radio sat around for a few days, then I did the chassis first.. that took a couple of days. Started working on the cabinet three days ago.. I stripped it on Monday, glued the wood to the dial on Tues, glued the veneer on yesterday and did the rest today. I started working on it at 8am today (sanding the veneer, I had already shaped the wood piece), and I finished up right before I posted this thread. It was pretty quick. It's a small radio and it doesn't get a piano finish.. so no grain filler or any polishing needed.
(This post was last modified: 09-12-2013, 06:49 PM by Jamie.)
Threads: 242
City: West Bend, Wisconsin
 Excellent work! I have one of these myself. It's a nice little set.
Threads: 242
Just noticed... yours, like mine, is missing the brass station call letter enclosure under the pushbuttons. I suspect previous owners nabbed them and sold 'em for brass scrap!
Threads: 337
City: lawrenceville nj
Great job looks fantastic
Threads: 18
City: Mesa, AZ
Very nice, indeed!!!
City: Kentucky
Thanks guys. I've got a small radio that needs to be stripped and refinished. No woodwork needed. If you'd like, I can post a step-by-step thread with photos. It would be sort of geared towards the first time refinisher. I plan to start on it today. Let me know if you think it's something you'd like to see.
(This post was last modified: 09-13-2013, 08:12 AM by Jamie.)
Absolutely!
City: Kentucky
Ok, done deal. I've got some work to do. I'll get started on the thread when I get back home this afternoon.
Threads: 276
City: Wilsonville
State, Province, Country: OR
Rogers Majestic R-646
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM |
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM |
Today I finished inspecting all the parts. The result is not very pleasing.
The first positive news:
1) The power tr...Vlad95 — 11:40 PM |
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM |
Well, maybe - maybe not :lol: It's been an interesting project so far! Something so simple, yet so cranky. The 1st one ...TV MAN — 05:12 PM |
Haven't thought of Burgess batteres in a while
https://www.radionostalgia.ca/lib/Images/battery/us/burgess1D.jpgi
...Vlad95 — 03:50 PM |
Measure the voltages first, just in case.morzh — 02:19 PM |
Haven't thought of Burgess batteries in a while Mr. Fixer. Boston Edison always used Burgess in their Bright Star yellow...Paul Philco322 — 02:17 PM |
Thanks Sam. I'll let you know. I can probably scare some up from the local radio club.klondike98 — 02:07 PM |
Philco 89 Code 123 Osc Coil
Hello,
I thought I would post my findings on my bad oscillator tickler coil. There were 27 turns on the outer coil b...dconant — 12:38 PM |
There are currently 929 online users. [Complete List] » 3 Member(s) | 926 Guest(s)
