Hum on FM
Well, here I go again. It looks like the most problems I have are some kind of hum and they're all different.
This one is a Zenith 79H20. After a recap, all tubes tested as well as resistors. AM sounds great. After an alignment FM pulls in many stations. Between stations there is a steady hum. To confuse me even more, when I touch the volume control shaft (using an isolation transformer) the hum gets a bit louder. I've checked all ground connections. Could I have missed a resistor or a mica cap?
This really is a great sounding radio. Any ideas?Icon_confused:
http://www.nostalgiaair.org/PagesByModel...025312.pdf
Eric
The Villages, FL
Looking at the schematic, it appears that the volume control is not directly grounded to the chassis, but rather through a .01 uF cap. This is probably why you get a hum when you touch the shaft.
C16, connected to the slider of the volume control looks like it was a shielded cap with a ground connection. If you replaced it with a normal cap, it may be picking up hum. Is C16 near any line voltage AC wiring? There has to be some reason why the original cap had a grounded shield.
How are you doing with the sweep generator and FM alignments?
Thanks, Mondial, I'll take a look at C16 and let you know. As far as the alignments go, first I want to thank you for pointing out this HP generator. It really seems to be getting the job done. Second, I'm starting to get the hang of it but my biggest problem is still knowing where to make the hook ups for gen and scope. I still haven't got a radio with visual alignment instructions but I think I'm starting to figure it out.
Eric
The Villages, FL
It looks like that did it, Mondial. I wrapped a coil of wire around C16 and grounded one end. I'm not saying that there is no hum, but it is now to the acceptable level for an AC/DC set.
Thanks
Eric
The Villages, FL
Theses Zeniths are very good sounding, many small enough to carry around the house. got a photo?
Here you go, Paul.
Eric
The Villages, FL
Unidentified Philco Bakelite
Possibly a UK radio. I make this presumption based on the Long Wave band. A photo of the back available? Take care, -...GarySP — 06:18 PM
Table radio 51C or 52C?
Morzh There are only 7 wires coming off the transformer. 3 for B+, 2 for 115 in and 2 for 5V to the 80. Maybe there i...antiqueradionut — 05:36 PM
Looks like a Tropic of some sort.morzh — 04:26 PM
The knobs I would guess are not original. PaulPaul Philco322 — 04:14 PM
This unit just became available on a local Canadian marketplace. The seller is unable to find a model number on the back...jrmott2 — 04:03 PM
Ok guys I've corrected the polarity of the area that popped the capacitor and resistor. I do have a question in regard t...osanders0311 — 04:02 PM
I would love to see the underside of that set, good luck and when you get that all cleaned up and running you will have ...Paul Philco322 — 03:17 PM
>>> Curious how this thing is getting 5V and 2.5V. Not sure I understood. There is that power transformer, it...morzh — 03:12 PM
I have noticed that Marconi cabinets, from that era, didn't really go overboard with the shading lacquer, at least on th...Arran — 02:16 PM
I realize there is a lot of butchery going on here to get it playing. I plugged it in and it didn't play! LOL But al...antiqueradionut — 01:23 PM
There are currently 1020 online users. [Complete List]
» 1 Member(s) | 1019 Guest(s)
