Can Anyone ID this radio?
I don't know what it is, but I own it... Icon_lol
I'm a sucker for art deco..
St. Thomas Cathedral?
It does look like a church!!
Here is a pic of the back.. maybe it will help.. The radio isn't here yet, so I can't pull the chassis or anything..
Yikes scary. How big is that thingIcon_eek
My body violently shuddered when I viewed the item! Icon_e_surprised I got the "willies", and the hair on my arms and the back of my neck are still standing on end!!! > I fear it.< Icon_eek
Looks like that edifice from the "Ghostbusters" movie.
It also comes with a complementary Philco or Majestic Rosette knob. It also has the rare brown paper grill cloth complete with stains, I wonder how the sound was supposed to get out?
Sympathic resonance. Icon_smile
Sorta looks like a Stewart Warner. Icon_think
Joe
High fidelity brown paper bag grill cloth, with a china white enamel finish. It does look sort of like a Stewart Warner, or a Crosley, but both would have the name on the dial escutcheon, and the Crosley would have a model number plate on the back of the chassis. By the chassis layout and the size of the components I would guess that it's from around 1935-36
I will transform it into a thing of great beauty and sound.... Icon_lol
It should arrive today or tomorrow. I'll let you know what it is..
I pulled the chassis and noticed these initials on the dial... JDA or DJA.. Ring a bell for anyone?
I just replaced the electrolytic caps, plugged it into the variac and it lives!!!!! Sounds pretty good too! ..
Mystery is solved... the name is stamped on the radio..
DeJur Corp.. NY, NY, along with several pat nos..
That would explain the DJA on the dial too...Anyone ever heard of them? Radio Museum says they made some kind of amp in 1926. No other info.
another d#%$&* gold mine I see Icon_silent
The whole idea is to keep the sound inside. Once you let it escape, it goes away and never comes back. Hence the Brown Paper.
Rogers Majestic R-646
By the way, the bypass you suggested is a rare solution in some circuits. For example, this schematics solution is used...Vlad95 — 01:43 PM
No, you are wrong, because you did not know the details. Unfortunately, only ONE winding out of six is intact in both t...Vlad95 — 01:14 PM
The output 45s are still in push-pull because the transformer secondary winding is still in the grid circuit providing o...RodB — 11:52 AM
Thanks RodB for the help. But this is not a real solution to this situation, not even a temporary one. Because the firs...Vlad95 — 11:34 AM
I was going to check the voltages as you suggested and hooked it up to my dim bulb. It appears I have a short. The bul...bobclausen — 10:34 AM
You can bypass the interstage transformer by disconnecting the primary, connect a load resistor of about 10k - 20k to th...RodB — 09:40 AM
So, here's Prince on stage halfway through Purple Rain when he stoops down to his tech and says "Rod, pull out that...RodB — 09:17 AM
Today I finished inspecting all the parts. The result is not very pleasing. The first positive news: 1) The power tr...Vlad95 — 11:40 PM
Well, found muh culprit. After using socket test adapters and finding voltages all ok, swapping 6V6s, no avail, swapped ...TV MAN — 11:18 PM
There are currently 1020 online users. [Complete List]
» 1 Member(s) | 1019 Guest(s)
