Philco ventilator
Picked it up a few days ago its in pretty good shape for its age ..motor mount was not rotted away like most seem to be ..Motor itself is getting a going over new bushings and had the rotor sanded and repainted (waiting for it to get back .
rear view
so far so good
got the waterslide decals from a fella at the antique fan collectors site
motor has bad bushings and caused the rotor to rub the stator ..but it is repairable ..new bushing being made .
an add from 1941
Very cool!
Well I'll be dipped in doggie doo!!!
That thing is NEAT.
Howard - EXCELLENT pictures and posts. Icon_thumbup This is great info, and perfectly illustrates the concept of "teaching with your posts."
That is BEAUTIFUL restoration work!
this PDf looks to be a later version of mine, that i assume was never put into production ..the rear door slides up and down instead of open and close . it also has a rear hood . iv wondered if it had any hardware that came with it ...i think it might have had a sash also .
rotor before giving it a good sanding with 220 grit .
Philco 42-1008 conversion kit
I read about a kit to convert the variable speed changer in the Philco 42-1008 into a single speed unit.  That would rem...alangard — 09:30 PM
Tim Well...a chassis is metal. Magnetic or not, it does not matter. A transformer has some hum to it. It is natural....morzh — 08:40 PM
Hickok AC51 tube tester
I thought the 83 tube was bad because it looked white but it tests strong. Blue gassy though. I checked the fuse, it was...martinj — 08:37 PM
Shadow Meter Bulb
Ross I am not sure what current limiting effect the incandescent provides. They are two different parts of the sch...morzh — 08:31 PM
12' Philco
Bob Thanks for that photo. I have been looking for it, and I cannot find anythinmg on the web. I forgot it was here...morzh — 08:29 PM
Shadow Meter Bulb
I think after all has been said, I will use the same bulb that is specified for the dial pilot light which is a #55. I ...georgetownjohn — 07:31 PM
12' Philco
There was also this Philco! klondike98 — 07:25 PM
I expected a challenge and this is just part of it. But, it's also supposed to be fun, entertaining, informative and enj...TV MAN — 07:12 PM
Shadow Meter Bulb
Butting in here with a question. Since the shadow meter is connected directly to the 1st and 2nd I.F.'s wouldn't the met...RossH — 06:43 PM
Mike, Tim; you are about to enter the twilight zone. Doo doo doo doo, doo doo doo doo This is something alright. I'm go...RodB — 06:26 PM
