Philco ventilator
Picked it up a few days ago its in pretty good shape for its age ..motor mount was not rotted away like most seem to be ..Motor itself is getting a going over new bushings and had the rotor sanded and repainted (waiting for it to get back .
rear view
so far so good
got the waterslide decals from a fella at the antique fan collectors site
motor has bad bushings and caused the rotor to rub the stator ..but it is repairable ..new bushing being made .
an add from 1941
Very cool!
Well I'll be dipped in doggie doo!!!
That thing is NEAT.
Howard - EXCELLENT pictures and posts. Icon_thumbup This is great info, and perfectly illustrates the concept of "teaching with your posts."
That is BEAUTIFUL restoration work!
this PDf looks to be a later version of mine, that i assume was never put into production ..the rear door slides up and down instead of open and close . it also has a rear hood . iv wondered if it had any hardware that came with it ...i think it might have had a sash also .
rotor before giving it a good sanding with 220 grit .
Correct model 84 Ac plug an cord type
From what I read Philco went to using brown rubber power cords in 1936, so cloth was used in the 1935 and earlier models...Arran — 11:25 PM
Hi Bruce, I have not worked on an 84, but in general, power cords for almost any radio prior to 1938 was cloth covered...MrFixr55 — 08:34 PM
Restoring Philco 38-14
OK, well, so after staring at the sch again, I realized the problem had to be the #12/12A padder. I put a scope on the o...morzh — 08:15 PM
Hello Bruce, I mostly use brown far as my cloth powercords go ! Here is the plug that I have used bakelite Acorn style...radiorich — 08:05 PM
Looking for as correct as can find the right Ac plug an the correct colored cloth line. Ive seen many old photos but mos...Bruce — 04:13 PM
Rod Two Y-caps make sense if you use them from L/N to the chassis; this is only makes sense in the transformer radios...morzh — 10:11 AM
Mike, I'm curious about a specific use of he Y cap. Lately I've seen a single cap across the power transformer primary. ...RodB — 09:01 AM
hello morzh , That sounds like a plan ! Sincerely Richardradiorich — 07:45 AM
Richard, It helped some, but I still had the whining when engaging the rear power strip (I did not realize it was fro...morzh — 07:07 AM
Hello morzh, Yes , that dreaded hum in my room where i do alighment I have my cable modem and router plus desktop plus ...radiorich — 11:25 PM
There are currently 4293 online users. [Complete List]
» 1 Member(s) | 4292 Guest(s)
