An 84B followed me home!
This is the radio that I was supposed to get two months ago, but that deal fell through. Well, I had something the guy wanted more and since this radio had failed to sell at his store, I did an even trade for it. Basically, I traded a $40 (repaired) 45-player for this repaired 84B that he had been trying to sell for $125. Plays really good and has joined the 37-84 in my bedroom. Only issue I had was it would play for 15-20 minutes and then slowly go silent before coming back on. Turned out the filament in the 42 was going out for some reason. I tossed in an untested 42 I bought for 50 cents at a sale and it now works fine. For some odd reason, these little Philco cathedrals are the only 4 tube radios that will work at my place with what antenna I can muster. I wonder why they do better than other makes?
Jayce, re-solder the pins on your original 42 tube and try it again.
M R Radios   C M Tubes
Looks like the tube is fine. Last night the other tube did the same trick and when I wiggled it, it would light again. So, it appears to be a socket issue, hopefully from some dirt. I gave the socket a couple shots of cleaner and put the original tube back in. It's working so far, so I hope that is all that was wrong.
Congrats on the new addition! Those are good looking sets. Sounds like you got a good deal too.
Great deal Jayce.
Jerry
Thanks! That 42 socket is still being a bit fussy, but the cleaning made it better. I'll keep babying it.
I just love these four tube Philcos! They work amazingly well for the low tube count and they sound better than the model 20 I listened to last year. Good tone from that big speaker. Now, should I try to find a model 80 or 81 next? Icon_biggrin
Try removing the 42 and carefully squeezing the tube socket contacts with a pair of needle nose pliers to restore spring tension against the pin. Sometimes a tube with a blob of solder at the end of the tube base pin will overstress a contact and cause a loss of tension.
Ok, will do if it doesn't settle down. I figure the issue is with the two biggest pins on the tube as I think those are the filament on a 42.
My Philco 37-116 Restore
Ron and Mike I mentioned a 2 meg resistor not on the schematic. I stumbled on a changes note in Riders that mentioned th...dconant — 12:02 PM
Need Help to ID this radio 11 tube Philco
Here you go: Your the code 125Radioroslyn — 11:12 AM
Hi Ron, Thanks for the input. I think I'm going to call it good enough. It does seem weird I can usually dial in othe...dconant — 08:01 AM
Welcome, the radio looks intimating 11 tubes, wish you well.Jimradio — 07:49 AM
Hi Dan, it’s been 10 years since I restored the electronics on my 37-116 so I’m going on some foggy memories. I remember...462ron — 07:37 AM
Yes the 16B as morzh pointed out. Specifically its the January 1935 model version of the 16B. There are a couple earli...klondike98 — 11:51 PM
48-482 rear panel help
Welcome to the Phorum, keithchip! How far you take a radio on cabinet restoration is a matter of personal preference. ...GarySP — 11:28 PM
I've recently finished the internal restoration of a locally purchased Philco 48-482. The cabinet is in ok shape except ...keithchip — 10:28 PM
Welcome to the Phorum, Ken! Lots of help here for all of your restoration questions. Take care and BE HEALTHY! - Gar...GarySP — 07:59 PM
Thank you. I went to your online library and found 2 schematics. I will download and compare to components!Ken D. — 06:31 PM
There are currently 738 online users. [Complete List]
» 2 Member(s) | 736 Guest(s)
