restoring a 41-265 help please.
I'm interested in knowing the top ten list for points on restoring a 41-265 I have. It powers up and pulls in AM stations only right now. I know the power cord needs to be replaced as do the volume and tone potentiometers. I'm sure there are some caps that should as well, but I would like an idea on which ones? As well, does anyone have a manual or worksheet on how to properly align the tuner so as to be able to pick up the other bands? I've downloaded what I can off the internet but I've yet to find a step by step on getting good alignment so as to maximize the stations one can pick up across all bands. Lastly, where does one pick up an extra tube set for this unit? I haven't tried looking on ebay just yet but will start doing this soon.
Any help would be much appreciated.
Cheers,
PS - Any idea on how to get a replacement speaker? The current one works, but it has a hole in the cone and is dry as dry can be.
Hi there,
Schematic and alignment info can be found here:
http://www.nostalgiaair.org/resources/413/M0013413.htm
Most people (including me) will suggest that ALL paper caps be replaced. They tend to be too troublesome to leave into place if you want a reliable radio. If you want to risk the bare minimum you can replace : the power supply filter caps (26, 26A, 39 on the diagram), Audio coupling #47, audio plate bypass #49, AC bypass caps (#57).
There are numerous places to buy tubes. I personally use http://www.findatube.com most of the time when buying assortments but frankly, unless there is something to indicate needing replacement tubes I wouldn't bother.
As for the speaker, the hole in the cone isn't an issue but I know what you mean about brittle. Most any original replacement is going to be equally brittle. There are places that do reconing but not inexpensive. Console sized speakers show up pretty often on ebay fairly cheap so you might just want to watch the marketplace for a while to see if you find a better one.
Good luck,
Bill
You might also find that your 1941 model has brittle rubber wiring which needs to be replaced. I justs bought a 41-250, and every wire will have to be changed. I like the radio, and would never expend the effort and time required to replace every wire on any radio I did not really like.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
A little bit of positivity in our feed... My new video... Test - the Philco 16B vs Philco 37-116 de Luxe / Test - the ...RadioSvit — 12:14 PM
Refinishing Ideas
Thanks. I will look into. Billpoulsbobill — 11:23 AM
My Philco 37-116 Restore
Why do the flood lights have 2 wires running to the shell of each light when the inner conductor only has one to each? ...dconant — 10:54 AM
OOPS!! if there is a "flag" running up the side of the tube that touches the shield, then yes, a shield belon...MrFixr55 — 10:03 AM
Thanks for pointing out that shield! I will try to find out where else it may belong. I simply installed it back where i...jrblasde — 10:02 AM
Very nice job. A real contrast between how easy the main chassis is to work on, vs how tightly the RF chassis is packed...MrFixr55 — 09:31 AM
After sleeping on it, I believe the issue is that I may have forgotten to install a ground connection between the RF cha...jrblasde — 09:21 AM
Refinishing Ideas
Hi Poulsbobl, I think that you could get away with it.  In the Philco Library, there is a parts listand specs for sp...MrFixr55 — 11:54 PM
The sleeving for the transformer arrived early, so I went ahead and finished reassembling. The chassis looks far better ...jrblasde — 10:15 PM
I don't know what you are referring to when you say "tube cathode ground". Ground is a connection to the chass...RodB — 05:56 PM
There are currently 698 online users. [Complete List]
» 1 Member(s) | 697 Guest(s)
